Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] ASCE Journal/Proceedings
[Request] ASCE Journal/Proceedings
 ynopum
Burundi
User ID: 2733
Threads: 26
Likes: 2,399 in 365 posts
Given Likes: 155
#31
10-06-2010, 04:45 PM
BOT:
[-] The following 6 users Like ynopum's post:6 users Like ynopum's post
  • Dell_Brett, yanburak, Vladimir, fer962933, warbeast, HungNguyen29
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Likes: 417 in 60 posts
Given Likes: 173
#32
10-07-2010, 04:52 PM
Good day, I am looking for these papers:
1. Experimental Study of Complex High-Strength Cold-Formed Cross-Shaped Steel Section
J. Struct. Engrg. Volume 134, Issue 8, pp. 1322-1333 (August 2008)
Derrick C. Y. Yap and Gregory J. Hancock
2. Design of Cold-Formed Steel Built-Up Closed Sections with Intermediate Stiffeners
J. Struct. Engrg. Volume 134, Issue 5, pp. 727-737 (May 2008)
Ben Young and Ju Chen
3. Compression Strength of Unstiffened Elements in Cold-Reduced High Strength Steel
J. Struct. Engrg. Volume 134, Issue 2, pp. 189-197 (February 2008)
J. Ye and K. J. R. Rasmussen
4. Determination of Composite Slab Strength Using a New Elemental Test Method
J. Struct. Engrg. Volume 133, Issue 9, pp. 1268-1277 (September 2007)
Redzuan Abdullah and W. Samuel Easterling
5. Full-Scale Test Behavior of Cold-Formed Steel Roof Trusses
J. Struct. Engrg. Volume 132, Issue 4, pp. 616-623 (April 2006)
James V. Wood and John L. Dawe
Thanks a lot, Vladimir.
[-] The following 2 users Like Vladimir's post:2 users Like Vladimir's post
  • fer962933, warbeast
 onest30
User ID: 21849
Threads: 9
Likes: 118 in 26 posts
Given Likes: 132
#33
10-07-2010, 06:38 PM
Vladimir,
find the papers listed below in the link at the bottom
here is the link:
[-] The following 9 users Like onest30's post:9 users Like onest30's post
  • leithowsky, goober, Dell_Brett, Vladimir, yanburak, malc, fer962933, warbeast, Grunf
 MonicaN
User ID: 24069
Threads: 10
Likes: 25 in 8 posts
Given Likes: 33
#34
10-11-2010, 08:36 AM (This post was last modified: 10-11-2010, 08:50 AM by concreteok.)
Hello.
Can you help me find this article :
Small-Scale Test Behavior of Cold-Formed Steel Roof Trusses
J. Struct. Engrg. 132, 616 (2006)
[-] The following 2 users Like MonicaN's post:2 users Like MonicaN's post
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
#35
10-11-2010, 09:42 AM
Hi MonicaN
find in this link as per requested.
hope it helps.
adekajeng
[-] The following 8 users Like Sumatra's post:8 users Like Sumatra's post
  • Dell_Brett, MonicaN, yanburak, Vladimir, goober, fer962933, warbeast, HungNguyen29
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Given Likes: 173
#36
10-12-2010, 08:01 AM
J. Struct. Engrg. Volume 132, Issue 4, pp. 608-615 (April 2006)
John L. Dawe and James V. Wood
Seismic Behavior of Sheathed Cold-Formed Structures: Physical Tests
J. Struct. Engrg. Volume 132, Issue 4, pp. 570-581 (April 2006)
Raffaele Landolfo, Luigi Fiorino, and Gaetano Della Corte
Seismic Behavior of Sheathed Cold-Formed Structures: Numerical Study
J. Struct. Engrg. Volume 132, Issue 4, pp. 558-569 (April 2006)
Gaetano Della Corte, Luigi Fiorino, and Raffaele Landolfo
Local-Plate and Distortional Postbuckling Behavior of Cold-Formed Steel Lipped Channel Columns with Intermediate Stiffeners
J. Struct. Engrg. Volume 132, Issue 4, pp. 529-540 (April 2006)
Nuno Silvestre and Dinar Camotim
Distortional Buckling of Cold-Formed Stainless Steel Sections: Finite-Element Modeling and Design
J. Struct. Engrg. Volume 132, Issue 4, pp. 505-514 (April 2006)
Maura Lecce and Kim Rasmussen
Thanks, Vladimir.
 onest30
User ID: 21849
Threads: 9
Given Likes: 132
#37
10-12-2010, 07:42 PM
Vladimir,
find the papers listed below in the link at the bottom:
Here is the link:
Best regards
[-] The following 7 users Like onest30's post:7 users Like onest30's post
  • Dell_Brett, Vladimir, yanburak, goober, Grunf, fer962933, warbeast
 peixoto
Portugal
User ID: 6963
Threads: 51
Likes: 968 in 114 posts
#38
10-13-2010, 12:54 PM
I need the following papers.
Cheng and Yura
Lateral buckling tests on coped steel beams
Journal of the Structural Division, ASCE, January 1988
Gupta
Buckling of coped steel beams
Journal of the Structural Division, ASCE, September 1984
Cheng, Yura and Johnson
Lateral buckling of coped steel beams
Thanks in advance.
[-] The following 2 users Like peixoto's post:2 users Like peixoto's post
 ynopum
Burundi
User ID: 2733
Threads: 26
Given Likes: 155
#39
10-13-2010, 05:12 PM (This post was last modified: 10-13-2010, 05:18 PM by Grunf.)
Peixoto, here it is: :pilot:
[-] The following 9 users Like ynopum's post:9 users Like ynopum's post
  • jcbv, saif.mulla, Vladimir, yanburak, peixoto, goober, Grunf, fer962933, warbeast
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Given Likes: 173
#40
10-14-2010, 06:07 PM
I'm looking for these papers:
Complex Edge Stiffeners for Thin-Walled Members
J. Struct. Engrg. Volume 132, Issue 2, pp. 212-226 (February 2006)
B. W. Schafer, A. Sarawit, and T. Peköz
Distortional Buckling of Cold-Formed Stainless Steel Sections: Experimental Investigation
J. Struct. Engrg. Volume 132, Issue 4, pp. 497-504 (April 2006)
Maura Lecce and Kim J. R. Rasmussen
Lateral Behavior of Plasterboard-Clad Residential Steel Frames
J. Struct. Engrg. Volume 125, Issue 1, pp. 32-39 (January 1999)
Emad F. Gad, Adrian M. Chandler, Colin F. Duffield, and Graeme Stark
Screwed Connection Tests of Thin G550 and G300 Sheet Steels
J. Struct. Engrg. Volume 125, Issue 2, pp. 128-136 (February 1999)
Colin A. Rogers and Gregory J. Hancock
Crippling Capacity of Web Elements with Openings
J. Struct. Engrg. Volume 125, Issue 2, pp. 137-141 (February 1999)
R. A. LaBoube, W. W. Yu, S. U. Deshmukh, and C. A. Uphoff
Thanks, Vladimir!
Pages (72): « Previous 1 2 3 4 5 6 7 8 9 10 … 72 Next »
  [REQUEST] ASCE Journal of Structural Engineering Vol. 132 (2006) mistahpablo 1 2,056 03-31-2017, 04:44 AM
Last Post: pezhmankhan
  [REQUEST] ASCE Journal of the Soil Mechanics and Foundation miquan 9 5,570 12-22-2014, 08:28 PM
Last Post: f_slikken
