Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC - Steel Design Guides
 Ernest0
Nicaragua
User ID: 15083
Threads: 38
Likes: 1,155 in 60 posts
Given Likes: 204
#31
12-26-2013, 09:19 PM (This post was last modified: 12-26-2013, 09:25 PM by Ernest0.)
Structural Stainless Steel
Author: NANCY BADDOO | Size: 20.3 MB | Format: PDF | Quality: Original preprint | Publisher: American Institute of Steel Construction | Year: 2013 | pages: 150
[Image: 30757217082579680935.jpg]
Design Guide 27, Structural Stainless Steel, provides guidance for the design of structural stainless steel. It is written for engineers experienced in the design of carbon steel structural components but not necessarily in the design of stainless steel structures, and is aligned with the design provisions in the 2010 AISC Specification for Structural Steel Buildings. It applies to the design of structural hot-rolled or welded open sections such as I-shaped members, channels, and equal-leg angles. It also applies to rectangular and round hollow structural sections (HSS). The guidance provided is applicable to austenitic, duplex and precipitation hardening stainless steel structural sections with thickness 1/8 in. (3 mm) and greater. Major topics covered are material behavior and selection, cross-section design, member design, connections, and fabrication. Design Examples are also included.
πŸ‘‰ CLICK HERE πŸ‘ˆ
Stability Design of Steel Buildings
Author: Lawrence G. Griffis, P.E, Donald W. White, Ph.D. | Size: 16 MB | Format: PDF | Quality: Original preprint | Publisher: American Institute of Steel Construction | Year: 2013 | pages: 176
[Image: 73202565741798899593.jpg]
With the 2005 AISC Specification for Structural Steel Buildings, the state of the art in structural steel design was advanced to include three methods for stability design, including the introduction of the powerful new approach - the direct analysis method. The primary purpose of this Design Guide is to discuss the application of each of the three methods - the direct analysis method, the effective length method, and the first-order analysis method - and to introduce the direct analysis method to practicing engineers. This Design Guide illustrates the application of the overall stability design requirements of the AISC Specification using representative examples taken from routine design office practice. Emphasis is placed on practical applications as opposed to theoretical derivations. (design guide 28)
[-] The following 51 users Like Ernest0's post:51 users Like Ernest0's post
  β€’ miquan, mastermind, Dell_Brett, pedzaquino, frank1972, usman, tomtumx, subin91, unix0123, Andrew seah, pezhmankhan, aslam, shaker, malc, ascetic19, zrilek, carolinandra, ssobhan, jcbv, rezart, mahyarov, vvvv, cace-01, oanm2000, ting tsai huang, ruaumoko, spiderthan, rfireman, ykhackhack, simanta, oscargon, bigone, inge911, yalham2000, blaze, taquya, avge, shalaka, Mohammad6299, nickycruz, vardan, stigtg, marcel1983, slowet, learner20, sodapas, K.Lee, bridgeengineer, harsono, lasalleguy, spat
Threads: 274
Likes: 12,075 in 1,233 posts
12-27-2013, 04:51 AM (This post was last modified: 12-27-2013, 05:09 AM by pezhmankhan.)
[-] The following 10 users Like pezhmankhan's post:10 users Like pezhmankhan's post
  β€’ aslam, Dell_Brett, zrilek, rezart, oanm2000, rfireman, bigone, blaze, jcbv, taquya
 Diquan
Costa Rica
User ID: 41
Threads: 23
Likes: 1,205 in 128 posts
Given Likes: 781
#33
01-02-2014, 11:05 AM (This post was last modified: 12-04-2014, 02:06 PM by mybest.)
Dears,
Here are all the Design Guides from AISC in one folder.
Every time a new Design Guide comes out, I'll put it on the folder.
The password for each one is:
Note:
Use The Latest WinRar to open this Archive (Winrar 5)
mybest
[-] The following 33 users Like Diquan's post:33 users Like Diquan's post
  β€’ Dell_Brett, ykhackhack, zrilek, ssobhan, jcbv, isurya, dl4all, junaid, tomtumx, ronnie_150, DavidMV, alcalan57, hosseinnet, shalaka, bigone, Mohammad6299, bogdanobi, nickycruz, malc, Andrew seah, PinkPant, mowafi3m, rezart, cabpcabp, dinu69in, amindoxiti, apocalipse, miquan, mikeagreer, eng donny, toa011, bridgeengineer, lasalleguy
 Ernest0
Nicaragua
User ID: 15083
Threads: 38
Given Likes: 204
#34
03-17-2015, 11:22 PM
Design Guide 29: Vertical Bracing Connections--Analysis and Design
Author: Larry S. Muir, P.E.;William A. Thornton, Ph.D., P.E. | Size: 16.8 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2014 | pages: 392
[Image: 88540335223056502671.jpg]
Design Guide 29, Vertical Bracing Connections--Analysis and Design, provides guidance for the design of vertical brace connections. The guide includes an overview of the design philosophy of common bracing systems based on structural principles. Using the lower bound theorem of limit analysis and the uniform force method, the guide addresses: brace-to-gusset connection, orthogonal and nonorthogonal connections, chevron or K-bracing, eccentric braces, connections at column base plates, both nonseismic and seismic conditions, and gusset plate stability. Design Guide 29 also includes over a dozen extensive, complete design examples with every applicable limit state addressed.
[-] The following 43 users Like Ernest0's post:43 users Like Ernest0's post
  β€’ tomtumx, RyanRS, Dell_Brett, taquya, amindoxiti, subin91, malc, unix0123, mahyarov, vardan, zrilek, simanta, vvvv, jcbv, agelos100, bridgeengineer, PinkPant, warlord1, knrsa, gulilero, cace-01, pedzaquino, Jackass, seriousboy, bigone, dinu69in, marcel1983, milova, slowet, yucapareja, Agent66, carolinandra, mgdario, ssobhan, oanm2000, taifur, rezart, sodapas, ralarcon, draluka, Aviator, harsono, spat
 eng donny
Indonesia
User ID: 765
Threads: 19
Likes: 1,976 in 236 posts
Given Likes: 905
#35
04-20-2015, 05:35 AM
[Image: 85392799835609667901.jpg]
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½
PASSWORD :
[-] The following 32 users Like eng donny's post:32 users Like eng donny's post
  β€’ dizz, K.Lee, malc, learner20, jcbv, ssobhan, cace-01, PinkPant, highcivil, simanta, oanm2000, zrilek, ascetic19, melekeen, Dell_Brett, araza023, Diquan, concreteok, bigone, Jackass, milova, psk62, anfaga, AndresPeper, bridgeengineer, pedzaquino, slowet, geomahesh, gulilero, munycamsec, harsono, spat
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
#36
04-20-2015, 10:16 AM
[-] The following 12 users Like junaid's post:12 users Like junaid's post
  β€’ PinkPant, oanm2000, melekeen, Dell_Brett, araza023, bigone, ersin, psk62, malc, ruaumoko, zrilek, f_slikken
 Ernest0
Nicaragua
User ID: 15083
Threads: 38
Given Likes: 204
#37
03-19-2016, 05:39 PM
Design Guide 30: Sound Isolation and Noise Control in Steel Buildings
[Image: 71473594560561162767.png]
  • Author(s): Benjamin Markham, LEED AP; Eric Ungar, Sc.D., P.E.
  • Published By: AISC
  • Published Year: 2015
  • Size: 2.35 MB
  • Quality: Original preprint
  • Abstract: The new AISC Design Guide 30: Sound Isolation and Noise Control in Steel Buildings provides the design team with readily accessible background information and with guidance aimed at achieving acoustical conditions suitable for a building’s planned occupancies. It also discusses sound isolation in detail - including the related metrics, effects of structural parameters and acoustical treatments, the effects of "weak links" such as acoustically inappropriate windows and gaps at doors, and the isolation performance of wall configurations that are widely used in steel buildings.
[-] The following 38 users Like Ernest0's post:38 users Like Ernest0's post
  β€’ amindoxiti, bridgeengineer, sabooryan, Agent66, zrilek, Jackass, tomtumx, struceng, simanta, f_slikken, RyanRS, subin91, usman, pedzaquino, spiritmedal, pezhmankhan, slowet, temp1366, jcbv, Dell_Brett, milova, cace-01, shaker, nickycruz, oanm2000, rendel_Β©, avge, agelos100, bigone, eng donny, ascetic19, PinkPant, cabpcabp, gulilero, toa011, dinu69in, malc, Aviator
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
#38
03-21-2016, 08:14 PM (This post was last modified: 03-21-2016, 08:16 PM by temp1366.)
Mirror:
[-] The following 6 users Like temp1366's post:6 users Like temp1366's post
  β€’ zrilek, ascetic19, Dell_Brett, PinkPant, oanm2000, mr.nicus
 ESTRUCTO
User ID: 2666
Threads: 1
Likes: 183 in 21 posts
Given Likes: 35
#39
07-31-2016, 03:08 AM
Aisc design guide 11 2nd edition.
[-] The following 20 users Like ESTRUCTO's post:20 users Like ESTRUCTO's post
  β€’ malc, Agent66, subin91, amindoxiti, bridgeengineer, zrilek, milova, slowet, Jackass, tomtumx, ashcivilea, ALMF, isurya, Dell_Brett, ascetic19, oanm2000, shaker, PinkPant, avge, dinu69in
 ESTRUCTO
User ID: 2666
Threads: 1
Given Likes: 35
#40
08-01-2016, 03:43 PM
Hello. Here is another link with all the AISC Design Guides (1 to 30), including errata.
[-] The following 13 users Like ESTRUCTO's post:13 users Like ESTRUCTO's post
  β€’ Jackass, zrilek, K.Lee, oanm2000, rezart, haze, Andrew seah, eng donny, PinkPant, bridgeengineer, Dell_Brett, Limpias72, malc
Pages (8): « Previous 1 2 3 4 5 6 7 8 Next »
  AISC 327: Seismic Design Manual weichunc 16 15,412 06-13-2026, 09:27 AM
  AISC - Steel Construction Manual dinu69in 26 28,025 06-10-2026, 12:17 PM
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 13,182 08-18-2025, 07:07 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,761 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 3,346 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 3,160 12-04-2023, 09:17 AM
  AISC: Facts for Steel Buildings tarugo 8 9,118 12-04-2023, 09:11 AM
