12-04-2012, 08:22 AM
Dear members,
can someone upload this article:
Negro, P., Pinto, A., Verzeletti, G., and Magonette, G. E.
Journal of Structural Engineering, Vol. 122, No. 12, December 1996, pp. 1409-1417
Abstract:
An experimental program was conducted on a four-story full-scale reinforced concrete building designed as a ductility class βhighβ structure in accordance with Eurocodes 2 and 8. The activity was defined as part of a cooperative research program by the European Association of Structural Mechanics Laboratories. The pseudodynamic tests were conducted for a serviceability-level and high-level earthquakeβ1.5 times the reference accelerogram. The results of the pseudodynamic tests are presented. General conclusions about the performance of the structure are drawn, with attention paid to the effects of the adoption of the new high-strength B500 Tempcore steel. The results make it possible to discuss the influence of the modeling parameters to be used in predicting the behavior of this class of structures. Effects such as the pullout and the slippage of the bars in the joints, or the participation of the slab to the global stiffness were found to play a fundamental role.
Can be found here:
π½π½π½π½π½π½π½π½π½
π CLICK HERE π
With regards,
PsD Test on Four-Story R/C Building Designed According to Eurocodes
Abstract:
Can be found here:
Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation:
π CLICK HERE π
With regards,
