Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Scitation and Sciencedirect/Elsevier JOURNAL
[Request] Scitation and Sciencedirect/Elsevier JOURNAL
 devilmaycry
User ID: 27027
Threads: 54
Likes: 232 in 63 posts
Given Likes: 460
#291
04-06-2013, 05:50 PM
  • Article/eBook Full Name: Seismic design of steel structures with buckling-restrained knee braces
  • Author(s): Jinkoo Kim
  • Publish Date: 2003
  • Published By: Journal of Constructional Steel Research
  • Related Links:
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
#292
04-06-2013, 06:49 PM
@devilmaycry
Here you go
[-] The following 2 users Like asim99's post:2 users Like asim99's post
  • malc, devilmaycry
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
#293
04-19-2013, 04:34 PM (This post was last modified: 04-19-2013, 04:41 PM by devilmaycry.)
  • Article/eBook Full Name: Dynamic stability analysis of functionally graded cylindrical shells under periodic axial loading
  • Author(s): T.Y. Ng
  • Publish Date: 2001
  • Related Links:
  • Article/eBook Full Name: Dynamic elastic–plastic buckling of circular cylindrical shells under axial impact
  • Author(s): D. Karagiozova
  • Publish Date: 2000
  • Related Links:
  • Article/eBook Full Name: Recent research advances on the dynamic analysis of composite shells: 2000–2009
  • Author(s): Mohamad S. Qatu
  • Publish Date: 2010
  • Related Links:
 asim99
User ID: 9774
Threads: 461
Given Likes: 377
#294
04-19-2013, 06:14 PM
@devilmaycry
Follow the link
 giguni
User ID: 20677
Threads: 73
Likes: 208 in 33 posts
Given Likes: 166
#295
04-24-2013, 03:10 PM
Article/eBook Full Name: Assessment of the stability of H/V spectral ratios from ambient noise and comparison with earthquake data in the Cologne area(Germany)
Author(s): S. Parolai, C. Milkereit,P. Bormann
Publish Date: 2004
Published By: ELSEVIER
Related Links:
Threads: 274
Likes: 12,075 in 1,233 posts
04-24-2013, 03:21 PM
Assessment of the stability of H/V spectral ratios from ambient noise and comparison with earthquake data in the Cologne area(Germany):
[-] The following 2 users Like pezhmankhan's post:2 users Like pezhmankhan's post
  • giguni, Dell_Brett
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
#297
04-24-2013, 03:29 PM
  • Article/eBook Full Name: The effects of long term uniform corrosion on the buckling of ground based steel tanks under seismic loading
  • Author(s): Mahmoud R. Maheri
  • Publish Date: 2013
  • Related Links:
 giguni
User ID: 20677
Threads: 73
Given Likes: 166
#298
04-24-2013, 04:09 PM
Article/eBook Full Name: Spectral analysis of ambient ground-motion—Noise reduction techniques and a methodology for mapping horizontal inhomogeneity
Author(s): M.Lambert
Publish Date: 2011
Related Links:
 devilmaycry
User ID: 27027
Threads: 54
Given Likes: 460
#299
04-24-2013, 04:12 PM (This post was last modified: 04-24-2013, 04:17 PM by devilmaycry.)
  • Article/eBook Full Name: A strain-consistent approach for determination of bounds of ductility damage index for different performance levels for seismic design of RC frame members
  • Author(s): Ashkan Sharifi, Mahmoud-Reza Banan, Mohammad-Reza Banan
  • Publish Date: 2012
  • Related Links:
  • Article/eBook Full Name: Detection and assessment of damage in 2D structures using measured modal response
  • Author(s): Mohammad Reza Banan, Yousef Mehdi-pour
  • Publish Date: 2007
  • Related Links:
  • Article/eBook Full Name: Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane loads
  • Author(s): M.A. Najafgholipour, Mahmoud R. Maheri, P.B. Lourenço
  • Related Links:
  • Article/eBook Full Name: Topology optimization of bracing in steel structures by genetic algorithm
  • Author(s): Mahmoud R. Maheri, D. Safari
  • Publish Date: 2005
  • Related Links:
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
#300
04-24-2013, 06:59 PM (This post was last modified: 04-24-2013, 07:41 PM by arshiakh.)
@devilmaycry
@devilmaycry
@giguni
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  • devilmaycry
Pages (50): « Previous 1 … 25 26 27 28 29 30 31 32 33 34 35 … 50 Next »
