Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Scitation and Sciencedirect/Elsevier JOURNAL
[Request] Scitation and Sciencedirect/Elsevier JOURNAL
 apocalipse
Portugal
User ID: 41527
Threads: 65
Likes: 790 in 87 posts
Given Likes: 922
#271
02-02-2013, 02:24 PM
Dear members,
I need the following paper:
Interaction formulae for members subjected to bending and axial compression in EUROCODE 3—the Method 2 approach
Author:
R. Greinera, , J. Lindnerb
Abstract:
The final version of EN1993-1-1, EUROCODE 3 [EN1993-1-1. Eurocode 3. Design of steel structures, general rules and rules for buildings. 2005] for Steel Structures provides two alternatives for the buckling check of members subjected to axial compression and bending by interaction formulae, which are called there Method 1 and Method 2. This paper presents the characteristics, the background and the use of Method 2. The analogous presentation of Method 1 has already been given in [Boissonnade N, Jaspart J-P, Muzeau J-P, Villette M. New Interaction formulae for beam-columns in Eurocode 3. The French-Belgian approach. Journal of Constructional Steel Research 2004;60;421–31].
The Method 2 formulae have been derived on the basis of the general format of the interaction concept of existing codes, e.g. the ENV-rules; however with advanced numerical background and consistent classification of the buckling modes. In this respect new improved interaction factors were developed from a wide scope of numerical simulations and the concept of the formulae was focussed distinctly on describing the modes of in-plane and out-of-plane buckling for members susceptible to fail either in flexural buckling or in lateral–torsional buckling. As result two sets of formulae are provided, which each cover a clear scope of physical member behaviour. Hereby, the specific effects of intermediate lateral restraints—as often found in steel structures—have also been included.
The Method 2 formulae aim at providing buckling rules with compact simplified interaction factors and transparent application for standard cases.
👉 CLICK HERE 👈
regards,
apocalipse
 mary
User ID: 31558
Threads: 37
Likes: 341 in 77 posts
Given Likes: 692
#272
02-02-2013, 10:16 PM
👉 CLICK HERE 👈
[-] The following 4 users Like mary's post:4 users Like mary's post
  • apocalipse, kowheng, malc, Dell_Brett
 apocalipse
Portugal
User ID: 41527
Threads: 65
Given Likes: 922
#273
02-08-2013, 09:53 AM
Dear members,
Design of steel and composite beams with web openings
Author:
Richard Redwood, Soon Ho Cho
Abstract
Composite or non-composite steel beams containing large web openings are considered. A general method of analysis suitable for design use is presented and related to a number of previous studies. Comparisons are made with the results of experimental research. Detailing of reinforcement and other design considerations are summarized; the material presented provides all the information necessary for design.
👉 CLICK HERE 👈
regards,
apcalipse
 rusty
Hungary
User ID: 17227
Threads: 56
Likes: 1,880 in 283 posts
Given Likes: 539
#274
02-08-2013, 09:58 AM (This post was last modified: 02-08-2013, 10:00 AM by rusty.)
👉 CLICK HERE 👈
[-] The following 4 users Like rusty's post:4 users Like rusty's post
  • apocalipse, Dell_Brett, malc, kowheng
 apocalipse
Portugal
User ID: 41527
Threads: 65
Given Likes: 922
#275
02-08-2013, 10:24 AM
Dear members,
Stability of built-up beams and columns with thin-walled members
Author:
Jacques Rondal, Majid Niazi
Abstract
The aim of this paper is to present experimental results on built-up elements composed of cold-formed C profiles with battened plates or C stitches.
The test results are compared with theoretical predictions obtained by means of the classical design method taking into account the Q factor when the profiles are thin-walled, for battened plates, and by means of a new design method for elements using C stitches.
A comparison of the results shows that both methods lead to a safe and accurate design.
👉 CLICK HERE 👈
regards,
apocalipse
 rusty
Hungary
User ID: 17227
Threads: 56
Given Likes: 539
#276
02-08-2013, 10:31 AM
👉 CLICK HERE 👈
[-] The following 5 users Like rusty's post:5 users Like rusty's post
  • apocalipse, Dell_Brett, Songoku, malc, kowheng
 Songoku
Azores
User ID: 2786
Threads: 16
Likes: 76 in 19 posts
Given Likes: 182
#277
02-08-2013, 02:15 PM
Hi everyone,
I need the following papers,
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
Thanks in advance
 rusty
Hungary
User ID: 17227
Threads: 56
Given Likes: 539
#278
02-08-2013, 02:50 PM
Dear Songoku,
All of the requested papers:
👉 CLICK HERE 👈
  • Dell_Brett, malc, Songoku, kowheng
 devilmaycry
User ID: 27027
Threads: 54
Likes: 232 in 63 posts
Given Likes: 460
#279
02-14-2013, 07:20 AM
Hi guys, I need these papers. Thanks in advance:
Ductile knee braced frames with shear yielding knee for seismic resistant structures
👉 CLICK HERE 👈
Preliminary studies into the behaviour of knee braced frames subject to seismic loading
👉 CLICK HERE 👈
Pushover tests on steel X-braced and knee-braced RC frames
👉 CLICK HERE 👈
Seismic behaviour factor, R, for steel X-braced and knee-braced RC buildings
👉 CLICK HERE 👈
Evaluating response modification factors of concentrically braced steel frames
👉 CLICK HERE 👈
Non-linear analysis of disposable knee bracing
👉 CLICK HERE 👈
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#280
02-14-2013, 08:10 AM
Dear devilmaycry
👉 CLICK HERE 👈
[-] The following 3 users Like ssobhan's post:3 users Like ssobhan's post
  • devilmaycry, malc, kowheng
Pages (50): « Previous 1 … 23 24 25 26 27 28 29 30 31 32 33 … 50 Next »
