Civil Engineering Association eBooks Codes, Manual & Handbook ACI MNL-17 - ACI Reinforced Concrete Design Handbooks (ACI SP 17)
Threads: 154
08-22-2012, 07:06 AM
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
👉 CLICK HERE 👈
[-] The following 8 users Like shadabg's post:8 users Like shadabg's post
  â€¢ ersin, david-smith, avscorreia, pedzaquino, bigone, Hengki, ykhackhack, crazyp86
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
#12
08-22-2012, 03:44 PM
ACI SP-17(09) ACI Design Handbook
Design of Structural Reinforced Concrete Elements in Accordance with ACI 318-05
Size: 5.5 MB | Format: PDF | Quality: Unspecified | Publisher: American Concrete Institute | Year: 2009 | pages: 252 | ISBN: 9780870313417
[Image: 41956620603300155070.jpg]
Abstract:
This publication provides information for the engineering design and analysis of beams, one-way slabs, footings, pile caps, columns, and seismic design in accordance with ACI 318-05. Information is presented in three sections: Explanatory Material, Design Examples, and Design Aids. The Introduction of each chapter includes explanatory material that provides the engineer with concise background of the subject. The Design Examples illustrate the use of the Design Aids, which are tables and graphs intended to eliminate routine and repetitious calculations.
Contents:
Chapter 1—Design for flexure
1.1—Introduction
1.2—Nominal and design flexural strengths (Mn and φMn)
1.3—Minimum flexural reinforcement
1.4—Placement of reinforcement in sections
1.5—Flexure examples
1.6—Flexure design aids
Chapter 2—Design for shear
2.1—Introduction
2.2—Shear strength of beams
2.3—Designing shear reinforcement for beams
2.4—Shear strength of two-way slabs
2.5—Shear strength with torsion and flexure
2.6—Shear design examples
2.7—Shear design aids
Chapter 3—Short column design
3.1—Introduction
3.2—Column sectional strength
3.3—Columns subjected to biaxial bending
3.4—Column examples
3.5—Column design aids
Chapter 4—Design of slender columns
4.1—Introduction
4.2—Slenderness ratio
4.3—Lateral bracing and designation of frames as non-sway
4.4—Design of slender columns
4.5—Slender column examples
4.6—Slender column design aids
Chapter 5—Footing design
5.1—Introduction
5.2—Foundation types
5.3—Allowable stress design and strength design
5.4—Structural design
5.5—Footings subject to eccentric loading
5.6—Footings examples
Chapter 6—Seismic design
6.1—Introduction
6.2—Limitations on materials
6.3—Flexural members of special moment frames
6.4—Special moment frame members subjected to bending and axial load
6.5—Joints of special moment frames
6.6—Members of intermediate moment frames
6.7—Members not designed as part of the lateral-force-resisting system
6.8—Seismic design examples
6.9—Seismic design aids
Chapter 7—References
7.1—Referenced standards and reports
7.2—Cited references
Appendix A—Reference tables
Appendix B—Analysis tables
Appendix C—Sectional properties
👉 CLICK HERE 👈
[-] The following 28 users Like usman's post:28 users Like usman's post
  â€¢ david-smith, Dell_Brett, ASEC, Jackass, ssobhan, ruaumoko, oscargon, paitaconst, pedzaquino, malc, kowheng, adams, Sumatra, isurya, gulilero, simanta, mahyarov, ykhackhack, oanm2000, tattiya, huan_maivn, bigone, techno, araza023, subin91, erimajus, Rapaig, harsono
 Ernest0
Nicaragua
User ID: 15083
Threads: 38
Likes: 1,155 in 60 posts
Given Likes: 204
#13
10-15-2012, 08:51 PM
Appendix
Size: 4.23 MB | Format: PDF | Quality: Unspecified
Appendix and Direct link to complete publication
👉 CLICK HERE 👈
[-] The following 20 users Like Ernest0's post:20 users Like Ernest0's post
  â€¢ eliseo.as, malc, kowheng, simanta, isurya, ersin, araza023, ruaumoko, seriousboy, erimajus, nickycruz, paitaconst, viet2010, subin91, ykhackhack, bigone, ssobhan, chicosi, jonygut, babakfeyzi
Threads: 274
Likes: 12,075 in 1,233 posts
03-30-2013, 04:06 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 8 users Like pezhmankhan's post:8 users Like pezhmankhan's post
  â€¢ knrsa, Dell_Brett, ykhackhack, bigone, promo8, Jackass, klsamy77, Munykong
Threads: 840
Likes: 9,411 in 1,161 posts
#15
10-04-2013, 07:12 PM (This post was last modified: 06-24-2015, 10:01 PM by oanm2000.)
This file is part of ACI SP-17(09) ACI Design Handbook
Short Column Design
Author: Noel. J. Everard and Mohsen A. Issa | Size: 1.5 MB | Format: PDF | Quality: Unspecified | Publisher: Professor Emeritus of Civil Engineering, the University of Texas at Arlington, Arlington, Texas. 2 Professor, Department of Civil and Materials Engineering, University of Illinois at Chicago, Illinois. | Year: August 2002 | pages: 113
[Image: 97393264386674680359.png]
The majority of reinforced concrete columns are subjected to primary stresses caused by flexure, axial force, and shear. Secondary stresses associated with deformations are usually very small in most columns used in practice. These columns are referred to as "short columns." Short columns are designed using the interaction diagrams presented in this chapter. The capacity of a short column is the same as the capacity of its section under primary stresses, irrespective of its length.
Long columns, columns with small cross-sectional dimensions, and columns with little end restraints may develop secondary stresses associated with column deformations, especially if they are not braced laterally. These columns are referred to as "slender columns". Fig. 3-1 illustrates secondary moments generated in a slender column by P-δeffect. Consequently, slender columns resist lower axial loads than short columns having the same cross-section. This is illustrated in Fig. 3-1. Failure of a slender column is initiated either by the material failure of a section, or instability of the column as a member, depending on the level of slenderness. The latter is known as column buckling.
👉 CLICK HERE 👈
[-] The following 16 users Like TAFATNEB's post:16 users Like TAFATNEB's post
  â€¢ ssobhan, vardan, rezart, malc, Dell_Brett, learner20, Hengki, ykhackhack, bigone, cace-01, blaze, melekeen, Mohammad6299, viet2010, oanm2000, ruaumoko
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
#16
05-12-2015, 01:35 PM (This post was last modified: 05-12-2015, 01:36 PM by bigone.)
SP-17M-09: ACI Design Handbook (Metric)
Design of Structural Reinforced Concrete Elements in Accordance with ACI 318M-05
👉 CLICK HERE 👈
many thanks for 1st uploader
[-] The following 31 users Like bigone's post:31 users Like bigone's post
  â€¢ PinkPant, rezart, pontiac, RyanRS, hatkam, cace-01, seriousboy, f_slikken, gianniorlati, tomtumx, viet2010, Rainbow, Munykong, simanta, Umer.Aleem, pezhmankhan, vvvv, oanm2000, ruaumoko, mgdario, heogay43, atram, denysitorus, mavilladar, xdesi, eng donny, blackjack, KhaLed-S.E, munycamsec, spat, milova
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
#17
08-03-2017, 10:27 PM (This post was last modified: 08-24-2021, 07:52 AM by Administrator.)
ACI SP-17(14): The Reinforced Concrete Design Handbook volume 1 & 2
Author(s):ACI : Edition:11 : Publish Date:2012 : ISBN:0870319221 : Published By:ACI
[Image: 65712417301376623589.jpg]
👉 CLICK HERE 👈
[-] The following 95 users Like mahyarov's post:95 users Like mahyarov's post
  â€¢ tomtumx, K.Lee, pedzaquino, RyanRS, ir_71, hatkam, tigran, PinkPant, zrilek, ASEC, ascetic19, gulilero, pontiac, versiondemo, mehabb, Nita1391, civilfafa, temp1366, Dell_Brett, shaker, cace-01, usman, spiritmedal, spiderthan, nickycruz, mgdario, apocalipse, ziggywas1, oanm2000, odiclas, amindoxiti, carolinandra, isurya, milova, techno, moh_towhid, junaid, miquan, mecheil.edwar, poite, simanta, Hengki, lisine, Umer.Aleem, Aviator, Ultra Zone, gcelayac, promo8, Batman07, abouferass88, bigone, user, pram, ruaumoko, KMABD, febo927, ahpearson, zainseiya, tolesa54, GMianG, Civilized, chicosi, smode, rendel_©, Andrew seah, caifan, Ivan_1980, fbx_rdnk, redtony, sacem, scorpion07, shanta, rfireman, Ekkaia, deltalead, kristoffer_89, malc, cheosmith, Sumatra, sructme, psppsp, ejaner, rangarajan, kowheng, tuanpecc1, ssobhan, ajmf77, atram, nhim4mat2006, Yasir, Rami11, blaze, weichunc, jonygut, spat
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 39
Likes: 1,063 in 98 posts
Given Likes: 490
#18
04-28-2019, 08:48 AM
ACI SP-17M(14)
Size: 150 MB | Format: PDF | Quality: Original preprint
[Image: 84719690646324635268.jpg]
👉 CLICK HERE 👈
[-] The following 36 users Like KhaLed-S.E's post:36 users Like KhaLed-S.E's post
  â€¢ zrilek, kowheng, jcbv, Aviator, tuanpecc1, cheosmith, Dell_Brett, coxxxyboy, tomtumx, promo8, carolinandra, simanta, pedzaquino, vvvv, pezhmankhan, lisine, cace-01, febo927, PinkPant, ssobhan, jcoronellr, pram, RyanRS, eng donny, oanm2000, ajmf77, atram, nhim4mat2006, i_kabir, rendel_©, monter, blaze, ir_71, krishna22045, CAMSECT, jonygut
 KMABD
User ID: 14195
Threads: 8
Likes: 682 in 36 posts
Given Likes: 111
#19
05-10-2020, 10:09 AM
Here it is. Use forum password.
👉 CLICK HERE 👈
[-] The following 21 users Like KMABD's post:21 users Like KMABD's post
  â€¢ gianniorlati, babakfeyzi, camto2, oanm2000, Dell_Brett, rendel_©, simanta, zrilek, jcbv, melekeen, PinkPant, sodapas, weichunc, gulilero, mohamz, Hengki, nhim4mat2006, krishna22045, jonygut, cace-01, spat
 jonygut
Nicaragua
User ID: 175427
Threads: 7
Likes: 286 in 17 posts
Given Likes: 322
#20
09-08-2020, 03:32 PM
The Reinforced Concrete Design Handbook A Companion to ACI 318-14 Volume 3: Design Aids SP-17(14)
Size: 9.88 MB | Format: PDF | Quality: Original preprint
[Image: 08542920216479446823.jpg]
👉 CLICK HERE 👈
[Image: comments.png]
These files can be free download on ACI's web site too.
👉 CLICK HERE 👈
[-] The following 26 users Like jonygut's post:26 users Like jonygut's post
  â€¢ hatkam, civilfafa, Dell_Brett, PinkPant, zrilek, jcbv, temp1366, simanta, lisine, babakfeyzi, Aviator, promo8, carolinandra, shaker, CAMSECT, tuanpecc1, tomtumx, bridge, kowheng, oanm2000, Wijono, amindoxiti, KhaLed-S.E, cace-01, khayagski, spat
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,451 08-17-2025, 10:25 AM
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,678 08-28-2024, 05:32 AM
  ACI 343: Analysis and Design of Reinforced Concrete Bridge Structures noelda2 3 5,240 05-12-2024, 10:46 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,892 03-04-2024, 08:35 AM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,923 03-04-2024, 07:50 AM
  ACI MNL-7: GFRP-Reinforced Concrete Design Handbook poolmand 0 2,210 01-08-2024, 05:05 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 2,053 11-26-2023, 11:51 AM
