Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Foundation Analysis and Design - Joseph E. Bowles
 JHIMY
User ID: 12445
Threads: 0
Likes: 7 in 1 posts
Given Likes: 1
#11
05-23-2011, 02:56 AM (This post was last modified: 05-23-2011, 03:00 AM by BennyP.)
Hi
I Submit new link of Bowles 3th edition
regards
Jhimy
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 7 users Like JHIMY's post:7 users Like JHIMY's post
  β€’ blaze, zonoiko, durden, bigone, manzoor_quadri, nickycruz, Ivan_1980
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
#12
11-21-2011, 08:37 PM (This post was last modified: 04-03-2013, 09:43 PM by Grunf.)
[Image: password.png].
[-] The following 6 users Like 3fan's post:6 users Like 3fan's post
  β€’ slowet, portal61, peymanlord, zonoiko, Dell_Brett, shadabg
Threads: 154
07-05-2012, 12:46 PM (This post was last modified: 04-25-2013, 10:13 AM by Grunf.)
Foundation Analysis and Design - Joseph Bowles (5th Edition)
Table of Contents
Preface
About the Computer Programs
List of Primary Symbols Used in Text
1 Introduction 1
2 Geotechnical And Index Properties: Laboratory Testing; Settlement and Strength Correlations 15
3 Exploration, Sampling, and In Situ Soil Measurements 135
4 Bearing Capacity of Foundations 213
5 Foundation Settlements 284
6 Improving Site Soils for Foundation Use 344
7 Factors to Consider in Foundation Design 370
8 Spread Footing Design 403
9 Special Footings and Beams on Elastic Foundations 472
10 Mat Foundations 537
11 Lateral Earth Pressure 589
12 Mechanically Stabilized Earth and Concrete Retaining Walls 657
13 Sheet-Pile Walls: Cantilevered and Anchored 725
14 Walls for Excavations 785
15 Cellular Cofferdams 828
16 Single Piles - Static Capacity and Lateral Loads; Pile/Pole Buckling 867
17 Single Piles: Dynamic Analysis, Load Tests 968
18 Pile Foundations: Groups 1006
19 Drilled Piers or Caissons 1055
20 Design of Foundations for Vibration Controls 1090
Preface:
This fifth edition continues the format of the previous four editions for providing current
state-of-art (SOA) and state-of-practice (SOP) methods in Foundation Engineering. From
author-user interaction I have concluded that SOP tends to lag SOA on the average of about
10 years. There is a range, however, where a few larger organizations are at the cutting edge
of technology and manyβ€”particularly the smaller firmsβ€”are at varying intermediate stages.
This textbook, which is also widely used as a practitioner's reference, includes SOP
material but with major emphasis on SOA. The latter is accomplished by including a mix
of practice, "how to," and latest suggested design/analysis methodology. This produces a
text compatible with the general goals of the American Society of Civil Engineers (ASCE)
and other professional organizations, which have determined that technical graduates have a
postgraduate period of only 5 to 7 years before obsolescence becomes a factor in their practice.
Design methods tend to vary between geographic regions, partly from instructors' influences
and partly because there are few "design absolutes." As a consequence it is necessary
to include the generally accepted alternative methods but to temper these with recommendations
and suggestions on their use. This allows the user access to regional differences and
provides "averaged" design results or the option to select the most appropriate alternative on
a site-specific basis. Although these comments may appear overly practice-oriented, the fact
is that the student must be aware of these real-world conflicts, geographical differences, and
alternatives so as to be productive upon graduation.
This book emphasizes computer methods and the Finite-Element Method (FEM), involving
matrix methods given in the previous editions, to reflect the widespread use of the
personal computer and of the FEM in practice. Be aware, however, that the finite-element
method does not have a unique definition. To some practitioners it is any mathematical representation
of the continua (beams, plates, or solids) using discrete (or finite) elements. To
other practitioners the FEM definition is reserved only for modeling the soil mass and the interfacing
structural elementsβ€”sometimes this is called "soil-structure interaction" modeling.
In this textbook the former definition is used, for it is the one that is most widely practiced
and given in most textbooks devoted solely to the FEM.
This textbook gives sufficient background theory for a FEM model so that the average
user should have little difficulty using this method for design/analysis of those types of soilstructure
interfacings used herein. It does make the modest assumption that most students at
the level of this textbook have been exposed to some FEM and matrix methodology in statics;
elementary structures; and the required university-level math courses. As a further aid there
are computer programs (already compiled on an accompanying diskette) so the user does not
have to become involved in FEM programming to use the methodology given.
More Alternate Links :
Mediafire unlock password: nhawe
For 5th Edition :
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½
[-] The following 27 users Like shadabg's post:27 users Like shadabg's post
  β€’ david-smith, ska51, Quantumm, simanta, gulilero, malc, Dell_Brett, hapsea, Jackass, bigone, LiviuM, ykhackhack, Mohammad6299, Trishu999, shalaka, Williams, jik686, nickycruz, jonny78, lednar_ved, Grunf, kirankumarklk, blaze, r.mehralizadeh, harsono, zrilek, carolinandra
Threads: 840
Likes: 9,411 in 1,161 posts
#14
08-30-2013, 11:09 PM (This post was last modified: 08-31-2013, 12:32 AM by usman.)
Mirror:
Fifth edition (chapter 20 only) DESIGN OF FOUNDATIONS FOR VIBRATION CONTROLS
  β€’ gulilero, bigone, blaze, Dell_Brett, oanm2000
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
#15
08-31-2013, 05:51 AM (This post was last modified: 08-31-2013, 05:52 AM by bigone.)
Author: Joseph E. Bowles | Edition: 5 | Year: 1995 |ISBN: 0079122477, 9780079122476
[-] The following 12 users Like bigone's post:12 users Like bigone's post
  β€’ malc, rezart, blaze, hapsea, Dell_Brett, cristi, harsono, Edudar, cace-01, ska51, ssobhan, Mohammad6299
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42508
#16
01-03-2015, 08:11 AM
Foundation Analysis and Design - 5th Ed.
Author: Joseph E. Bowles | Size: 57,2 MB | Format: PDF | Quality: Scanner | Publisher: McGraw-Hill Science/Engineering/Math | Year: 1995-09-01 | pages: 1.230 | ISBN: 0079122477
The revision of this best-selling text for a junior/senior course in Foundation Analysis and Design now includes an IBM computer disk containing 16 compiled programs together with the data sets used to produce the output sheets, as well as new material on sloping ground, pile and pile group analysis, and procedures for an improved analysis of lateral piles. Bearing capacity analysis has been substantially revised for footings with horizontal as well as vertical loads. Footing design for overturning now incorporates the use of the same uniform linear pressure concept used in ascertaining the bearing capacity. Increased emphasis is placed on geotextiles for retaining walls and soil nailing.
[-] The following 19 users Like Dell_Brett's post:19 users Like Dell_Brett's post
  β€’ cace-01, ska51, ssobhan, amindoxiti, blaze, oanm2000, PinkPant, learner20, Mohammad6299, bigone, bridgeengineer, shadabg, hodzicemir, seraneng, malc, zrilek, mgdario, pedzaquino, K.Lee
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
#17
01-03-2015, 11:12 PM
5Th Edition
use official password
[-] The following 8 users Like Veggeta's post:8 users Like Veggeta's post
  β€’ shadabg, TAFATNEB, oanm2000, PinkPant, bridgeengineer, Dell_Brett, ykhackhack, hodzicemir
 lucaPOLInuvola
Italy
User ID: 165554
Threads: 0
Likes: 0 in 0 posts
Given Likes: 10
#18
11-05-2015, 10:24 PM
Hello I'm looking for this book anyone has this document?
  β€’
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
#19
11-06-2015, 02:12 AM
last two links still valid. the rest could be so as well.
concrete solution advocate
[-] The following 3 users Like concreteok's post:3 users Like concreteok's post
  β€’ PinkPant, oanm2000, Dell_Brett
 jhaws
Australia
User ID: 100277
Threads: 2
Likes: 5 in 2 posts
Given Likes: 3
#20
11-19-2015, 05:49 AM
Could someone please re-post the dead link.
  β€’
  Foundation Engineering Analysis and Design cace-01 0 2,021 02-04-2018, 06:42 PM
Last Post: cace-01
  Analytical and Computer Methods in Foundation Engineering - Joseph E Bowles RyanRS 4 4,057 01-20-2015, 12:43 PM
Last Post: PinkPant
  Pile Foundation Analysis and Design by H G Poulos Dell_Brett 8 10,032 01-30-2014, 01:12 PM
Last Post: bigone
  Foundation Analysis and Design: 1. Mat Foundations, 2. Retaining Walls aidil01 4 4,992 01-29-2012, 09:16 AM
Last Post: jokerβ„’
