Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC Design Examples
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
#11
05-20-2012, 06:28 AM (This post was last modified: 05-20-2012, 06:37 AM by bigone.)
Steel Construction Manual Design Examples, V14.0
Author: AISC | Size: 13 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2011 | pages: 884
[Image: 24391910679570266034.png]
This version of the Steel Construction Manual Design Examples is consistent with the 2010 AISC Specification for Structural Steel Buildings and the 14th Edition Steel Construction Manual. The AISC Design Examples V14.0 contains 155 examples illustrating the application of both documents.
👉 CLICK HERE 👈
or
👉 CLICK HERE 👈
also AISC V14 section Database
👉 CLICK HERE 👈
or
👉 CLICK HERE 👈
[Image: comments.png]
it is free document from AISC
[-] The following 9 users Like bigone's post:9 users Like bigone's post
  â€¢ blaze, stosto6666, malc, subin91, david-smith, oanm2000, ykhackhack, lednar_ved, Andrew seah
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
#12
03-27-2013, 03:58 AM (This post was last modified: 10-08-2019, 01:32 PM by oanm2000.)
Steel Construction Manual Design Examples, V14.1
Author: AISC | Size: 12.12 MB | Format: PDF | Quality: Unspecified | Publisher: AISC | Year: 2013 | pages: 928
[Image: 01432599007921428633.jpg]
The primary objective of these design examples is to provide illustrations of the use of the 2010 AISC Specification for Structural Steel Buildings (ANSI/AISC 360-10) and the 14th Edition of the AISC Steel Construction Manual.
The design examples provide coverage of all applicable limit states whether or not a particular limit state controls the design of the member or connection.
In addition to the examples which demonstrate the use of the Manual tables, design examples are provided for connection designs beyond the scope of the tables in the Manual. These design examples are intended to demonstrate an approach to the design, and are not intended to suggest that the approach presented is the only approach. The committee responsible for the development of these design examples recognizes that designers have alternate approaches that work best for them and their projects. Design approaches that differ from those presented in these examples are considered viable as long as the Specification, sound engineering, and project specific requirements are satisfied.
Part I of these examples is organized to correspond with the organization of the Specification. The Chapter titles match the corresponding chapters in the Specification.
Part II is devoted primarily to connection examples that draw on the tables from the Manual, recommended design procedures, and the breadth of the Specification. The chapters of Part II are labeled II-A, II-B, II-C, etc.
Part III addresses aspects of design that are linked to the performance of a building as a whole. This includes coverage of lateral stability and second order analysis, illustrated through a four-story braced-frame and momentframe building.
The Design Examples are arranged with LRFD and ASD designs presented side by side, for consistency with the AISC Manual. Design with ASD and LRFD are based on the same nominal strength for each element so that the only differences between the approaches are which set of load combinations from ASCE/SEI 7-10 are used for design and whether the resistance factor for LRFD or the safety factor for ASD is used.
👉 CLICK HERE 👈
Download directly from AISC
[-] The following 18 users Like asim99's post:18 users Like asim99's post
  â€¢ ting tsai huang, malc, ssobhan, Andrew seah, ykhackhack, Dell_Brett, kowheng, red_pool61, Diquan, bigone, Jackass, maijuji, vinnunsam, zrilek, harsono, chairatpk, oanm2000, jacky899
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
#13
02-24-2019, 10:59 AM
DESIGN EXAMPLES Companion to the AISC Steel Construction Manual Version 15.0
Author(s)/Editor(s): AISC | Size: 12.60 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2017 | pages: 1609
[Image: 45683109958618231418.jpg]
👉 CLICK HERE 👈
[-] The following 24 users Like mowafi3m's post:24 users Like mowafi3m's post
  â€¢ kowheng, usman, oanm2000, Nita1391, zrilek, hatkam, rezart, cace-01, cargadory2k, subin91, Aviator, pedzaquino, febo927, lisine, Andrew seah, amindoxiti, jcbv, PinkPant, avge, ssobhan, Dell_Brett, jcoronellr, pram, bigone
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
#14
10-07-2019, 07:57 PM
DESIGN EXAMPLES Companion to the AISC Steel Construction Manual Version 15.1
Author(s)/Editor(s): AISC | Size: 9.65 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2019 | pages: 1609
👉 CLICK HERE 👈
[-] The following 26 users Like temp1366's post:26 users Like temp1366's post
  â€¢ rami1976, malc, kowheng, rodleyzed, milova, cheosmith, pedzaquino, odiclas, zrilek, highcivil, sabooryan, Andrew seah, PinkPant, febo927, oanm2000, Nita1391, tuanpecc1, CAMSECT, rendel_©, melekeen, cace-01, subin91, Dell_Brett, mohamz, mecheil.edwar, nibbi
Threads: 769
Likes: 8,311 in 1,373 posts
Given Likes: 94
#15
01-18-2022, 11:59 AM
Steel Construction Manual Design Examples, V15.0
| Size: 10.58 MB| Format: PDF| Quality: Original preprint| Publisher: AISC| Year: 2017
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ Dell_Brett, kowheng
Threads: 769
Given Likes: 94
#16
01-18-2022, 12:00 PM (This post was last modified: 01-18-2022, 12:07 PM by amindoxiti.)
Steel Construction Manual Design Examples, V15.1
| Size: 7.79 MB| Format: PDF| Quality: Original preprint| Publisher: AISC| Year: 2019
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ amindoxiti, cheosmith, babakfeyzi, Dell_Brett, kowheng, vinnunsam
Threads: 769
Given Likes: 94
#17
01-18-2022, 12:50 PM
AISC Design Guides (1 to 36) - Latest Editions (2022/01/18)
You can Download each file separately
  • Design Guide 1: Column Base Plates, 2nd Edition
  • Design Guide 2: Design of Steel, Composite Beams with Web Openings
  • Design Guide 3: Serviceability Design for Low-Rise Buildings, 2nd Edition
  • Design Guide 4: Extended End-Plate Moment Connections, 2nd Edition
  • Design Guide 5: Design of Low- and Medium-Rise Steel Buildings
  • Design Guide 6: LRFD of W-Shapes Encased in Concrete
  • Design Guide 7: Industrial Buildings: Roofs to Column Anchorage, 3rd Edition
  • Design Guide 8: Partially Restrained Composite Connections
  • Design Guide 9: Torsional Analysis of Structural Steel Members
  • Design Guide 10: Erection Bracing of Low-Rise Structural Steel Frames, 2nd Edition
  • Design Guide 11: Floor Vibrations Due To Human Activity, 2nd Edition
  • Design Guide 12: Modification of Existing Steel Welded Moment Frame
  • Design Guide 13: Wide-Flange Column Stiffening at Moment Connections
  • Design Guide 14: Staggered Truss Framing Systems
  • Design Guide 15: AISC Rehabilitation and Retrofit Guide, 2nd Edition
  • Design Guide 16: Flush, Extended Multiple-Row Moment Connections
  • Design Guide 17: High Strength Bolts--A Primer for Structural Engineers
  • Design Guide 18: Steel-Framed Open-Deck Parking Structures
  • Design Guide 19: Fire Resistance of Structural Steel Framing
  • Design Guide 21: Welded Connections - A Primer for Engineers, 2nd Edition
  • Design Guide 22: Facade Attachments To Steel Framed Buildings
  • Design Guide 23: Constructability of Structural Steel Buildings
  • Design Guide 24 - Hollow Structural Section Connections
  • Design Guide 25: Frame Design Using Web-Tapered Members - 2nd Edition
  • Design Guide 26: Design of Blast Resistant Structures
  • Design Guide 27: Structural Stainless Steel
  • Design Guide 28: Stability Design of Steel Buildings
  • Design Guide 29: Vertical Bracing Connections--Analysis and Design
  • Design Guide 30: Sound Isolation and Noise Control in Steel Buildings
  • Design Guide 31: Castellated and Cellular Beam Design
  • Design Guide 32: Design of Modular Steel-Plate Composite Walls for Safety-Related Nuclear Facilities
  • Design Guide 33: Curved Member Design
  • Design Guide 34: Steel-Framed Stairway Design
  • Design Guide 35: Steel-Framed Storm Shelters
  • Design Guide 36: Design Considerations for Camber
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  â€¢ jcbv, babakfeyzi, Dell_Brett, kowheng, Administrator , vinnunsam, mecheil.edwar
Pages (2): « Previous 1 2
  AISC - Steel Design Guides Administrator 75 87,811 06-13-2026, 09:38 AM
  AISC 327: Seismic Design Manual weichunc 16 15,416 06-13-2026, 09:27 AM
  AISC 205: AISC Certification Program for Steel Bridge Fabricators Administrator 2 4,300 01-19-2022, 05:18 AM
  AISC 316: AISC Manual of Steel Construction Grunf 3 6,869 04-08-2020, 04:53 AM
Last Post: KMABD
