Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC 358: Prequalified Connections for Special and Intermediate Steel Moment Frames
 ESTRUCTO
User ID: 2666
Threads: 1
Likes: 183 in 21 posts
Given Likes: 35
#11
12-05-2018, 01:19 PM
ANSI/AISC 358-16
ANSI/AISC 358s1-18
An American National Standard
This supplement was developed by the AISC Connection Prequalification Review Panel (CPRP) using a consensus process. This document is the first supplement to ANSI/AISC 358-16, Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications.
This supplement adds a new prequalified moment connection, the proprietary SlottedWeb Moment Connection, in a new Chapter 14. Chapter 11 covering the SidePlate Moment Connection has been expanded to include HSS columns and to permit bolted connections. Additionally, Chapter 10 covering the ConXtech CONXL Moment Connection has been revised to address a manufacturing safety issue.
A nonmandatory Commentary has been prepared to provide background for the provi-sions of the Standard, and the user is encouraged to consult it. Additionally, nonmandatory User Notes are interspersed throughout the Standard to provide concise and practical guid-ance in the application of the provisions.
May 12, 2016
(includes 2018 supplement)
Approved by the Connection Prequalification Review Panel
DIRECT DOWNLOAD LINK
👉 CLICK HERE 👈
[-] The following 22 users Like ESTRUCTO's post:22 users Like ESTRUCTO's post
  â€¢ Aviator, vvvv, melekeen, febo927, blaze, agelos100, oanm2000, gianniorlati, promo8, jcbv, sabooryan, rami1976, caifan, frank1972, subin91, Dell_Brett, PinkPant, mgdario, Nita1391, munycamsec, spat, CAMSECT
 melekeen
User ID: 24116
Threads: 12
Likes: 614 in 42 posts
Given Likes: 1353
#12
07-08-2020, 07:29 PM
ANSI/AISC 358-16
ANSI/AISC 358s1-18
ANSI/AISC 358s2-20
(includes 2018 and 2020 supplements)
This publication includes both Supplement No. 1 and Supplement No. 2 to ANSI/AISC 358-16, Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications. This standard is developed by the AISC Connection Prequalification Review Panel (CPRP) using a consensus process.
Supplement No. 2 expands the prequalification scope of Chapter 11 SidePlate Moment Connection and Chapter 12 Simpson Strong-Tie Strong Frame Moment Connection. The SidePlate moment connection prequalification has been expanded to include a new biaxial configuration with HSS or built-up box columns as well as a new bolted configuration, Configuration C (tuck). The Simpson moment connection prequalification has been expanded to include an end-plate connection for smaller beams, stronger Yield-Links, a design procedure for the Yield-Link buckling restraint mechanism, and beam and column limitations.
A nonmandatory Commentary has been prepared to provide background for the provisions of the Standard, and the user is encouraged to consult it. Additionally, nonmandatory User Notes are interspersed throughout the Standard to provide concise and practical guidance in the application of the provisions.
👉 CLICK HERE 👈
[-] The following 19 users Like melekeen's post:19 users Like melekeen's post
  â€¢ rami1976, milova, kowheng, Dell_Brett, subin91, tuanpecc1, zrilek, Aviator, babakfeyzi, gulilero, PinkPant, oanm2000, cace-01, caifan, Ivan_1980, jcoronellr, CAMSECT, bridge, mgdario
Threads: 769
Likes: 8,311 in 1,373 posts
Given Likes: 94
#13
11-03-2021, 07:37 AM (This post was last modified: 01-12-2022, 11:16 AM by Administrator.)
AISC 358-22 Public Review
| Size: 11.9 MB| Format: PDF| Quality: Original preprint| Publisher: AISC| Year: 2022| pages: 296
[Image: 29652653568750063120.png]
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ jcbv, Dell_Brett, PinkPant, simanta, kowheng, oanm2000, Wijono, mohamz, spat
Threads: 769
Given Likes: 94
#14
12-04-2023, 08:52 AM
AISC 358-22: Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
| Size: 13.02 MB| Format: PDF| Quality: Original preprint| Publisher: AISC
[Image: 04957293880698171181.png]
The prequalified connections standard has been developed by the AISC Connection Prequalification Review Panel in accordance with Chapter K of the Seismic Provisions for Structural Steel Buildings. The connections have been prequalified for use in special and intermediate steel moment frames without the need for additional testing.
The standard (2022) addresses 11 moment connections:
reduced beam section (RBS)
bolted unstiffened and stiffened extended end-plates
bolted flange plate (BFP)
welded unreinforced flange-welded web (WUF-W)
cast bolted bracket (CBB)
ConXtech CONXL connection | patent holder statement*
SidePlate connection | patent holder statement*
Simpson strong-tie strong frame | patent holder statement*
double-tee moment connection
slotted web (SW) moment connection
DuraFuse Frames moment connection | patent holder statement*
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  â€¢ PinkPant, cheosmith, Dell_Brett, red_pool61, subin91, Umer.Aleem, jcbv, kowheng, babakfeyzi, Hengki
Pages (2): « Previous 1 2
  AISC - Steel Design Guides Administrator 75 87,811 06-13-2026, 09:38 AM
  AISC - Steel Construction Manual dinu69in 26 28,028 06-10-2026, 12:17 PM
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 13,182 08-18-2025, 07:07 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,761 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 3,346 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 3,160 12-04-2023, 09:17 AM
  AISC: Facts for Steel Buildings tarugo 8 9,118 12-04-2023, 09:11 AM
