Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers Journal of Wind Engineering and Industrial Aerodynamics
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Likes: 2,013 in 182 posts
Given Likes: 753
#11
10-05-2011, 05:40 AM
Volume 99, Issue 8, Pages 801-896 (August 2011)
Size: 11.7 MB | Format: PDF
1.Editorial Board
2.Improved modelling of downburst outflows for wind engineering applications using a cooling source approach
Pages 801-814
Brian C. Vermeire, Leigh G. Orf, Eric Savory
3.Added-mass estimation of flat membranes vibrating in still air
Pages 815-824
Li Yuanqi, Lei Wang, Zuyan Shen, Yukio Tamura
4.Off-axis characterization of ice-free anemometers
Pages 825-832
André Bégin-Drolet, Jean Ruel, Jean Lemay
5.2D and 3D numerical simulation of the wind-rotor/nacelle interaction in an atmospheric boundary layer
Pages 833-844
Khaled Ameur, Christian Masson, Peter J. Eecen
6.2D and 3D numerical simulation of the wind-rotor/nacelle interaction in an atmospheric boundary layer
Pages 833-844
7.An experimental investigation of the wind environment and air quality within a densely populated urban street canyon
Pages 857-867
Mahmoud Bady, Shinsuke Kato, Takeo Takahashi, Hong Huang
8.Flow patterns and vortex shedding behavior behind a square cylinder
Pages 868-878
Shun C. Yen, Chen W. Yang
9.Numerical simulation of wind flow over transverse and pyramid dunes
Pages 879-888
Benli Liu, Jianjun Qu, Weimin Zhang, Guangqiang Qian
10.Influence of an upstream building on the wind-induced mean suction on the flat roof of a low-rise building
Pages 889-893
Santiago Pindado, José Meseguer, Sebastián Franchini
11.Erratum to “Simplified prediction of wind-induced response and stability limit of slender long-span suspension bridges, based on modified quasi-steady theory: A case study” [J. Wind Eng. Ind. Aerodyn. 98 (2010), 730–741]
Page 894
Ole Øiseth, Anders Rönnquist, Ragnar Sigbjörnsson
12.Calendar
Page 895
👉 CLICK HERE 👈
[-] The following 13 users Like foxxx2010's post:13 users Like foxxx2010's post
  • kowheng, 3fan, Dell_Brett, ivanveliki, tluc, marion33, MarcinX, sodapas, lisine, chairatpk, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#12
10-06-2011, 12:29 PM
Volume 99, Issue 9, Pages 897-996 (September 2011)
Size: 12.4 MB | Format: PDF
1.Editorial Board
Special Section: 9th UK Conference on Wind Engineering
2.JWEIA foreword to WES-2010 special issue
Pages 897-898
J.H.G. Macdonald, M.D. Burton
3.A wind-tunnel study of flow distortion at a meteorological sensor on top of the BT Tower, London, UK
Pages 899-907
Janet F. Barlow, James Harrison, Alan G. Robins, Curtis R. Wood
4.Aerodynamic design of a kinetic sculpture
Pages 908-918
Douglas Greenwell, Eva MacNamara
5.Shape-dependent characteristics of full-scale wind profiles
Pages 919-930
Mathias Clobes, Andreas Willecke, Udo Peil
6.Numerical simulation of the airflow–rivulet interaction associated with the rain-wind induced vibration phenomenon
Pages 931-944
Ian J. Taylor, Andrew C. Robertson
REGULAR PAPERS
7.Simulation of linear and non-linear propagation effects of a random turbulence field on bridge flutter instability
Pages 945-954
Luca Caracoglia
8.Long-term monitoring of wind-induced responses of a large-span roof structure
Pages 955-963
Ji Young Kim, Eunjong Yu, Dae Young Kim, Yukio Tamura
9.Wind loads on heliostats and photovoltaic trackers at various Reynolds numbers
Pages 964-968
A. Pfahl, H. Uhlemann
10.Neutral and non-neutral atmosphere: Probabilistic characterization and wind-induced response of structures
Pages 969-978
Maria Pia Repetto
11.The Florida Coastal Monitoring Program (FCMP): A review
Pages 979-995
J.A. Balderrama, F.J. Masters, K.R. Gurley, D.O. Prevatt, L.D. Aponte-Bermúdez, T.A. Reinhold, J.-P. Pinelli, C.S. Subramanian, S.D. Schiff, A.G. Chowdhury
12.Calendar
👉 CLICK HERE 👈
[-] The following 12 users Like foxxx2010's post:12 users Like foxxx2010's post
  • 3fan, kowheng, Dell_Brett, tluc, marion33, MarcinX, sodapas, lisine, chairatpk, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#13
10-10-2011, 05:59 AM
Volume 99, Issue 10, Pages 997-1116 (October 2011)
Size: 13.3 MB | Format: PDF
1.Editorial Board
Page IFC
2.The new editorial board
Page 997
Ted Stathopoulos
3.Announcement of the Alan G. Davenport Wind Loading Chain
Pages 998-999
4.Wind tunnel tests on heavy road vehicles: Cross wind induced loads—Part 1
Pages 1000-1010
F. Cheli, R. Corradi, E. Sabbioni, G. Tomasini
5.Wind tunnel tests on heavy road vehicles: Cross wind induced loads—Part 2
Pages 1011-1024
F. Cheli, F. Ripamonti, E. Sabbioni, G. Tomasini
6.Wind tunnel tests on compartment fires with crossflow ventilation
Pages 1025-1035
H.X. Chen, N.A. Liu, W.K. Chow
7.Experimental and numerical studies of flows through and within high-rise building arrays and their link to ventilation strategy
Pages 1036-1055
Jian Hang, Yuguo Li, Mats Sandberg
8.ILES of flow over low-rise buildings: Influence of inflow conditions on the quality of the mean pressure distribution prediction
Pages 1056-1068
D.A. Köse, D. Fauconnier, E. Dick
9.Vortex-induced vibration tests of circular cylinders connected with typical joints in transmission towers
Pages 1069-1078
H.Z. Deng, Q. Jiang, F. Li, Y. Wu
10.Apparent wind load effects on the tether of a kite power generator
Pages 1079-1088
I. Argatov, P. Rautakorpi, R. Silvennoinen
11.Study of the flow between the train underbody and the ballast track
Pages 1089-1098
Javier García, Antonio Crespo, Aitor Berasarte, Javier Goikoetxea
12.A review of water tank modeling of the convective atmospheric boundary layer
Pages 1099-1114
Renmin Yuan, Xuping Wu, Tao Luo, Huizhi Liu, Jianning Sun
13.Calendar
Page 1115
👉 CLICK HERE 👈
[-] The following 11 users Like foxxx2010's post:11 users Like foxxx2010's post
  • Dell_Brett, tluc, kowheng, marion33, MarcinX, sodapas, lisine, chairatpk, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#14
01-19-2012, 04:49 PM
Volume 99, Issue 11, Pages 1117-1186 (November 2011)
Size: 6.03 MB | Format: PDF | Quality: Unspecified
1.Editorial Board
2.Publisher'{}s Note
Page iii
3.Characterization of flow oblique to a circular cylinder with low aspect ratio using 3-D detached eddy simulation
Pages 1117-1125
DongHun Yeo, Nicholas P. Jones
4.A hybrid RANS and kinematic simulation of wind load effects on full-scale tall buildings
Pages 1126-1138
M.F. Huang, I.W.H Lau, C.M. Chan, K.C.S. Kwok, G. Li
5. Long-term simulation of the mean wind speed
Pages 1139-1150
Alessio Torrielli, Maria Pia Repetto, Giovanni Solari
6. Internal pressure dynamics of a leaky building with a dominant opening
Pages 1151-1161
T.K. Guha, R.N. Sharma, P.J. Richards
7. Evaluation of wind load integration in disproportionate collapse analysis of steel moment frames for column loss
Pages 1162-1173
S. Gerasimidis, C.C. Baniotopoulos
8. Force transfer mechanism on fastener section of mechanically anchored waterproofing membrane roofs under wind pressure during typhoons
Pages 1174-1183
Hiroyuki Miyauchi, Nobuo Katou, Kyoji Tanaka
9. Erratum to “Quasi-static combination of wind loads: A copula-based approach” [J. Wind Eng. Ind. Aerodyn. 99 (2011) 672–681]
Page 1184
Gianni Bartoli, Claudio Mannini, Tommaso Massai
10. Calendar
Page 1185
👉 CLICK HERE 👈
[Image: comments.png]
RARed PDFs
[-] The following 9 users Like foxxx2010's post:9 users Like foxxx2010's post
  • kowheng, tluc, marion33, MarcinX, sodapas, lisine, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#15
01-20-2012, 09:16 PM
Volume 99, Issue 12, Pages 1187-1252 (December 2011)
Size: 5.6 MB | Format: PDF | Quality: Original preprint
1. Volume 99, Issue 12, Pages 1187-1252 (December 2011)
2. Aerodynamic characteristics of a tube train
Pages 1187-1196
Tae-Kyung Kim, Kyu-Hong Kim, Hyeok-Bin Kwon
3. Experimental investigation of wake structure around an external rear view mirror of a passenger car.
Pages 1197-1206
Jeong-Hyun Kim, Yong Oun Han
4. Orthogonal expansion of Gaussian wind velocity field and PDEM-based vibration analysis of wind-excited structures
Pages 1207-1220
Zhang-Jun Liu, Jian-Bing Chen, Jie Li
5. Aeroelastic divergence and flutter: Critical comments on the regulations of EN 1991-1-4.
Pages 1221-1226
Arno Kirch, Mathias Clobes, Udo Peil
6. A wind-tunnel study on diffusion from urban major roads.
Pages 1227-1242
Isao Kanda, Yukio Yamao, Kiyoshi Uehara, Toshimasa Ohara
7. Mitigation of vortex-induced vibrations in bridges under conflicting objectives.
Pages 1243-1252
Atul Patil, Sungmoon Jung, Seungho Lee, Soon-Duck Kwon
8. Calendar
Page I
👉 CLICK HERE 👈
RARed PDFs
  • kowheng, marion33, blaze, MarcinX, sodapas, lisine, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#16
01-21-2012, 06:44 AM
Volume 100, Issue 1, Pages 1-92 (January 2012)
Size: 15.3 MB | Format: PDF | Quality: Original preprint
1. Editorial Board
Page IFC
2. Large eddy simulation of wind effects on a long-span complex roof structure.
Pages 1-18
C.L. Lu, Q.S. Li, S.H. Huang, F.B. Chen, X.Y. Fu
3.Field measurements of aerodynamic pressures in tunnels induced by high speed trains.
Pages 19-29
Yung-Yen Ko, Cheng-Hsing Chen, Ing-Tsang Hoe, Shin-Tsyr Wang
4.Coupling between structural and fluid dynamic problems applied to vortex shedding in a 90 m steel chimney.
Pages 30-37
Ali Vasallo Belver, Antolín Lorenzana Ibán, Carlos E. Lavín Martín
5.An innovative low-profile monolithic constant-temperature anemometer.
Pages 38-45
David M. Birch, Jonathan F. Morrison
6.The turbulent Ekman boundary layer over an infinite wind-turbine array.
Pages 46-57
Roderick Johnstone, Gary N. Coleman
7. The response of an overhead electrical power transmission line to two types of wind forcing.
Pages 58-69
W.E. Lin, E. Savory, R.P. McIntyre, C.S. Vandelaar, J.P.C. King
8.Internal pressures – The dominant windward opening case – A review.
Pages 70-76
J.D. Holmes, J.D. Ginger
9. On the stochastic nature of compact debris flight.
Pages 77-90
A. Karimpour, N.B. Kaye
10.Calendar
Page 91
👉 CLICK HERE 👈
RARed PDFs
  • kowheng, lisine, tluc, Dell_Brett, marion33, blaze, MarcinX, sodapas, slowet, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#17
02-23-2012, 08:25 AM
Volume 101, Pages 1-86 (February 2012)
Size: 4.6 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
RARed PDFs
  • Dell_Brett, kowheng, blaze, tluc, marion33, sodapas, chairatpk, slowet, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#18
02-27-2012, 08:23 AM
Volume 102, Pages 1-98 (March 2012)
Size: 12 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
RARed PDFs
  • Dell_Brett, kowheng, 3fan, marion33, tluc, MarcinX, sodapas, chairatpk, slowet, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#19
03-29-2012, 09:42 AM
Volume 89, 2001
Size: 43.8 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
Volume 88, 2000
Size: 9.5 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
Volume 87, 2000
Size: 8.7 MB | Format: PDF | Quality: Unspecified
👉 CLICK HERE 👈
[-] The following 10 users Like foxxx2010's post:10 users Like foxxx2010's post
  • 3fan, kowheng, MarcinX, marion33, sodapas, lisine, chairatpk, Mohammad6299, hodzicemir, zrilek
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Given Likes: 753
#20
03-29-2012, 11:10 AM
Volume 86, 2000
Size: 6.8 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
Volume 85, 2000
Size: 8.3 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
Volume 84, 2000
Size: 13.7 MB | Format: PDF | Quality: Original preprint
👉 CLICK HERE 👈
  • kowheng, mahyarov, MarcinX, marion33, sodapas, lisine, chairatpk, Mohammad6299, hodzicemir, zrilek
Pages (4): « Previous 1 2 3 4 Next »
  ASCE Journal of Structural Engineering (2003~ 2009) Badis 5 13,066 03-23-2017, 03:27 PM
Last Post: camto2
  B&SE - The Bridge & Structural Engineering Journal RyanRS 1 7,037 11-22-2015, 09:08 PM
  Journal of Geotechnical & Geoenvironmental Engineering lisine 15 25,737 05-26-2015, 10:26 AM
  Paper of Journal of Engineering Mechanics peixoto 1 5,942 12-01-2010, 05:11 PM
Last Post: hich
  Journal of Engineering Mechanics 1983;109(3):691–705. lizard 1 5,799 11-26-2010, 01:25 PM
Last Post: hich
