Civil Engineering Association Forum Discussion FAQs, Q&A, comments [PROBLEM] Problem with Postgen
Thread Closed
[Problem] Problem with Postgen
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
#11
03-31-2011, 04:42 PM
Kowheng warned you for repeating transparent links and not for fonts. I only corrected your previous post without warning and you felt offended. Read one more time my post and my PM. I make faults but i check my posts 10 times using Preview Post and i recommended you the same. I supose you can see the warning rate percents when you look at your post, press the left mouse button on percent and see the reason of warning without asking here.
  • kowheng, Grunf
03-31-2011, 04:46 PM (This post was last modified: 03-31-2011, 04:52 PM by kowheng.)
cesar,
Using PostGen is not an accuse to not to be warned. PosGen is just a tool to accommodate users. Users have to follow/abide forum rules. You/users should see the code generated by PostGen, if you understood it, you will post the right things according to forum rules.
Comparison: PostGen is calculator. The result from calculator, all of engineers must computed it without calculator. Now calculator is out of order, but users complain that "I got the wrong result of 2+2 is not equal to 4". This is the same situation as yours.
[-] The following 1 user Likes kowheng's post:1 user Likes kowheng's post
  • Grunf
 cesar
User ID: 31044
Threads: 6
Likes: 93 in 14 posts
Given Likes: 49
#13
03-31-2011, 05:03 PM (This post was last modified: 03-31-2011, 05:12 PM by kowheng.)
honestly i tried to write the same code on the post gen but it gave me the link with fonts why i don't know
ok i will accept the warning respectably
with my note : tried all different methods on the post gen & the codes on the topic replying tool but gave me the same
ok sorry for wasting your time & please if the problem is fixed just send me a notification as i have much to serve members
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 282
Likes: 21,191 in 2,352 posts
Given Likes: 4260
#14
03-31-2011, 07:49 PM
Check it now.
I think the problem was solved
:yes::connie_nutzo:
[-] The following 3 users Like Administrator 's post:3 users Like Administrator 's post
  • rezart, Dell_Brett, ir_71
Pages (2): « Previous 1 2
