Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Share your Staad Knowlegde
 engr1900
Semi Senior Member
Banned
User ID: 4169
Threads: 31
Likes: 251 in 53 posts
Given Likes: 1176
#11
10-01-2009, 05:41 PM
Hy all
SHIFTING OF UCS OR ORIGIN IN STAADPRO
Yes its a good topic we can share our knowledge in case of staadpro
recently i modelled a difficult frame structure in autocad and exported as DXF to inport in staadpro, but i forgot to shift the origin in autocad
since when when we apply the floor load in staadpro we need to define the x and z ranges so as apply the 2 way slab load
since the origin in staadpro was away from the first node , was not able to define the x and z ranges, what i did is noted the x y z coordinates of node 1 (it was something like this 3.482 9 -3.557), then selected all nodes, right clicked, slected the move command and entered the above coordinates and this worked and i am done with origin shifting in staadpro, may be simple for others but felt very relax when i am done with this..............though i could have shifted easily in AutoCAD
byeeeeeeee
[-] The following 2 users Like engr1900's post:2 users Like engr1900's post
  • errohit, barjinder
 sarapatuse
User ID: 6381
Threads: 2
Likes: 55 in 10 posts
Given Likes: 49
#12
10-01-2009, 06:49 PM
I think that also can be done using the move origin command....
[-] The following 2 users Like sarapatuse's post:2 users Like sarapatuse's post
  • engr1900, engr1900
 engr1900
Semi Senior Member
Banned
User ID: 4169
Threads: 31
Given Likes: 1176
#13
10-03-2009, 07:39 AM
Hy
before analyzing it is recommended to check your model, like supports, multiple structures, dimensions.........etc etc
plz share more about staadpro
byeeee
  • niki102, niki102
 zbizafar
User ID: 1998
Threads: 46
Likes: 889 in 86 posts
Given Likes: 333
#14
10-03-2009, 03:55 PM
Few tips for the newbies in Staad.
1- Always define seismic definations and load first before any other load case.
2- Always use repeat load combinations for P-Delta analysis.
3- Check for default strength of concrete and steel.
4- Always use load list for analysis / design, otherwise you will be stuck with primary load other than combination which you do not want.
Correct me if i am wrong, i will appreciate it. Would love to hear from other members too.
Thanks and regards,
[-] The following 7 users Like zbizafar's post:7 users Like zbizafar's post
  • timosi™, timosi™, niki102, niki102, engr1900, engr1900, barjinder
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
#15
10-03-2009, 04:24 PM
while designing RCC components in STAAD...
it is recommended to use RC-Designer mode instead of using direct command prompt..
[-] The following 4 users Like niki102's post:4 users Like niki102's post
  • zbizafar, zbizafar, engr1900, engr1900
 02410021
User ID: 5803
Threads: 7
Likes: 17 in 6 posts
Given Likes: 1
#16
10-04-2009, 08:37 AM
if you encounter such error like seismic load must be define first something like that. so that you will not delete all you have define load data's to modify and place seismic then other loads you can used STAAD editor to correct it
it is a matter of copy and paste method for the rearrangement of loads
 zbizafar
User ID: 1998
Threads: 46
Given Likes: 333
#17
10-04-2009, 12:46 PM
I problem that i have encountered using staad is, you cannot import circular lines like helix from dxf file. For that one of my friend told me to model it in sap than import it in Staad. it is a good option if u know Sap. Anyone who have imported helix , ramp, stairs from dxf please share. May be i did something wrong...
Thanks and regards,
 engr1900
Semi Senior Member
Banned
User ID: 4169
Threads: 31
Given Likes: 1176
#18
10-04-2009, 03:38 PM
Hy
As far Geometric stairs are concerned you can use "reverse cylindrical coordinates" syetem, i will post it here
byeeee
[-] The following 1 user Likes engr1900's post:1 user Likes engr1900's post
  • barjinder
 engr1900
Semi Senior Member
Banned
User ID: 4169
Threads: 31
Given Likes: 1176
#19
10-04-2009, 05:20 PM
Hy
Use of reverse cylindrical coordinate system in Staadpro to model a geometric stair
plz check the link for staadpro program
byeee
screenshots:
[Image: 2a78j7t.jpg]
Download Links:
👉 CLICK HERE 👈
[-] The following 4 users Like engr1900's post:4 users Like engr1900's post
  • zbizafar, zbizafar, errohit, barjinder
 engr1900
Semi Senior Member
Banned
User ID: 4169
Threads: 31
Given Likes: 1176
#20
10-05-2009, 11:26 AM
Hy
plz use reverse cylindrical coordinate system
something like this
JOI COO CYLINDRICAL REV
1 1 0 0 22 1 4 270
R A 4 .3 0 0
ele inci
1 1 2 24 23 TO 21
R A 3 21 22
if u r confuse, do let me know
byeeeee
[-] The following 8 users Like engr1900's post:8 users Like engr1900's post
  • vvvv, vvvv, niki102, niki102, zbizafar, zbizafar, falconado, barjinder
Pages (5): « Previous 1 2 3 4 5 Next »
