Civil Engineering Association eBooks Journals, Papers and Presentations ACI Structural Journal Collection
 adshrt
User ID: 8297
Threads: 35
Likes: 1,203 in 114 posts
Given Likes: 364
#11
04-22-2011, 05:27 AM (This post was last modified: 05-07-2012, 07:07 PM by mybest.)
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 7 users Like adshrt's post:7 users Like adshrt's post
  β€’ thebeatles, attila, monter, Jackass, malc, Umer.Aleem, bigone
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
#12
09-27-2011, 02:13 PM (This post was last modified: 05-07-2012, 07:11 PM by mybest.)
Volume 87(1990) Issue 3
[-] The following 7 users Like 3fan's post:7 users Like 3fan's post
  β€’ shahrekord, Dell_Brett, Jackass, tluc, Umer.Aleem, bigone, kgelling
 yanburak
User ID: 27551
Threads: 74
Likes: 821 in 94 posts
Given Likes: 421
#13
10-20-2011, 08:57 PM (This post was last modified: 01-31-2012, 11:26 PM by 3fan.)
New links issue 1-6 vol 88:
[-] The following 6 users Like yanburak's post:6 users Like yanburak's post
  β€’ Dell_Brett, chairatpk, lisine, marion33, malc, bigone
 yanburak
User ID: 27551
Threads: 74
Given Likes: 421
#14
01-31-2012, 11:08 PM (This post was last modified: 05-07-2012, 07:14 PM by mybest.)
Volume 88(1991) Issue 1 to 6
Alive, check 5th 8 2012
[-] The following 7 users Like yanburak's post:7 users Like yanburak's post
  β€’ mybest, Dell_Brett, malc, tluc, majkyy, mahyarov, bigone
 yanburak
User ID: 27551
Threads: 74
Given Likes: 421
#15
10-30-2012, 09:59 PM (This post was last modified: 10-30-2012, 10:01 PM by yanburak.)
New link (vol 87 issue 1 to 6)
[-] The following 4 users Like yanburak's post:4 users Like yanburak's post
  β€’ mahyarov, bigone, kgelling, Mohammad6299
 RyanRS
Indonesia
User ID: 32427
Threads: 175
Likes: 4,684 in 228 posts
Given Likes: 765
#16
07-09-2014, 06:51 AM
ACI Structural Journal Vol 110 No. 6 (Nov-Dec 2013)
Size: 46 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2013 | pages: 226
[Image: 67136493248636653004.jpg]
909 Shear Database for Prestressed Concrete Members
919 Carbon Fiber-Reinforced Polymer Punching Reinforcement and Strengthening of Concrete Flat Slabs
929 Lattice-Reinforced Slab-Column Connections under Cyclic Lateral Loading
941 Fiber-Reinforced Polymer-Confined Circular Columns under Simulated Seismic Loads
953 Seismic Behavior of High-Strength Concrete Structural Walls with Edge Columns
965 Computational Modeling of Aramid Fiber-Reinforced Polymer Prestressed Girder in Composite Action with Bridge Deck
977 Influence of Temperature Cycles on Bond between Glass FiberReinforced Polymer and Concrete
989 Behavior of Normal- and High-Strength Confined Concrete
1001 Shaking Table Tests on Reinforced Concrete Frames without Seismic Detailing
1013 Behavior of Deep Beams with Large Headed Bars
1023 Reliability Analysis of Concrete Beams Internally Reinforced with Fiber-Reinforced Polymer Bars
1033 Behavior of Reinforced Concrete Membrane Elements Subjected to Bidirectional Shear Loads
1045 Experimental Lateral Load Response of Unbonded Post-Tensioned Precast Concrete Walls
1057 Testing of Reinforced Concrete Coupling Beams: Part I
1067 Modeling of Reinforced Concrete Coupling Beams: Part II
1077 Flexural Behavior and Serviceability of Normal- and High-Strength Concrete Beams Reinforced with Glass Fiber-Reinforced Polymer
1089 Anchorage of Carbon Fiber-Reinforced Polymer on Side Faces of Reinforced Concrete Beams to Provide Continuity
1099 Residual Tensile Capacity of Grouted Post-Tensioned Tendons
[-] The following 12 users Like RyanRS's post:12 users Like RyanRS's post
  β€’ ssobhan, ykhackhack, Mohammad6299, nima_b12, Dell_Brett, malc, bridgeengineer, vardan, zrilek, cordoba123, subin91, jamesmakeez
 RyanRS
Indonesia
User ID: 32427
Threads: 175
Given Likes: 765
#17
07-12-2014, 07:50 PM
ACI Structural Journal Vol 110 No. 1 (Jan-Feb 2013)
3 Ultimate Strength Domain of Reinforced Concrete Sections under Biaxial Bending and Axial Load
15 Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concrete Slabs
27 Shortening Estimation for Post-Tensioned Concrete Floorsβ€”Part I: Model Selection
35 Shortening Estimation for Post-Tensioned Concrete Floorsβ€”Part II: Calculations
43 Shear Behavior of Reinforced High-Strength Concrete Beams
53 Design of Anchor Reinforcement for Seismic Shear Loads
63 Innovative Flexural Strengthening of Reinforced Concrete Columns Using Carbon-Fiber Anchors
71 Adaptive Stress Field Models: Formulation and Validation
83 Adaptive Stress Field Models: Assessment of Design Models
95 Flexural Drift Capacity of Reinforced Concrete Wall with Limited Confinement
105 Shake-Table Studies of Repaired Reinforced Concrete Bridge Columns Using Carbon Fiber Reinforced Polymer Fabrics
115 Cyclic Loading Test for Reinforced-Concrete-Emulated BeamColumn Connection of Precast Concrete Moment Frame
127 Unified Calculation Method for Symmetrically Reinforced Concrete Section Subjected to Combined Loading
137 Cyclic Behavior of Substandard Reinforced Concrete Beam-Column Joints with Plain Bars
[-] The following 9 users Like RyanRS's post:9 users Like RyanRS's post
  β€’ cordoba123, Mohammad6299, malc, subin91, zrilek, ssobhan, bridgeengineer, PinkPant, jamesmakeez
 RyanRS
Indonesia
User ID: 32427
Threads: 175
Given Likes: 765
#18
04-18-2015, 04:10 PM
ACI Structural Journal (Mar-Apr & Jan-Feb 2015)
Size: 27 MB | Format: PDF | Quality: Unspecified | Publisher: ACI | Year: 2015 | pages: 146 & 122
[Image: 57837719263731826626.png]
[Image: 15692373057800756910.png]
[Image: 68987625204664316539.png]
[-] The following 26 users Like RyanRS's post:26 users Like RyanRS's post
  β€’ Veggeta, vardan, faros3000, ssobhan, zrilek, oanm2000, malc, concreteok, ykhackhack, amindoxiti, f_slikken, Dell_Brett, learner20, PinkPant, melekeen, Ultra Zone, viet2010, tomtumx, bridgeengineer, subin91, techno, bigone, Mohammad6299, sodapas, Sumatra, febo927
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
#19
04-20-2015, 08:09 AM
#16 mirror
concrete solution advocate
[-] The following 12 users Like concreteok's post:12 users Like concreteok's post
  β€’ PinkPant, f_slikken, oanm2000, melekeen, Dell_Brett, Ultra Zone, Photon, viet2010, malc, bridgeengineer, Mohammad6299, sodapas
 RyanRS
Indonesia
User ID: 32427
Threads: 175
Given Likes: 765
#20
04-21-2015, 10:09 PM
ACI Structural Journal (Mar-Apr 2014)
Author: ACI | Size: 43 MB | Format: PDF | Quality: Original preprint | Year: 2014 | pages: 258
[Image: 30157460553553230911.png]
[Image: 43476498323909165754.jpg]
[-] The following 25 users Like RyanRS's post:25 users Like RyanRS's post
  β€’ Dell_Brett, viet2010, Ultra Zone, malc, amindoxiti, vardan, ykhackhack, zrilek, blaze, ssobhan, PinkPant, concreteok, melekeen, oanm2000, monter, kgelling, bridgeengineer, simanta, subin91, techno, bigone, Mohammad6299, sodapas, Sumatra, febo927
  Journal of Structural Engineering - Papers lisine 10 19,763 06-07-2013, 06:41 AM
  Journal Earthquake Engineering & Structural Dynamics - Papers lisine 5 11,269 02-12-2013, 10:56 AM
  JOURNAL OF STRUCTURAL ENGINEERING Β© ASCE / JANUARY - JUNE 2009 cve_jule 6 15,332 01-23-2013, 05:28 PM
Last Post: fer962933
  Journal: Earthquake Engineering & Structural Dynamics faros3000 6 12,826 11-05-2012, 12:50 PM
Last Post: mybest
  Journal Structural and Multidisciplinary Optimization - Requested papers lisine 0 4,290 09-03-2012, 07:52 AM
  The Collection of SSA Journal (Seismological Research Letter Articles) melkat 7 16,820 02-04-2012, 03:13 PM
Last Post: mybest
  The Collection of SSA Journal (Bulletin of Seismological Society of America) melkat 2 7,392 02-17-2011, 03:41 PM
Last Post: melkat
