Civil Engineering Association Various Free Discussion Tonnage Estimation for steel structure.
 RedHorse
Philippine
User ID: 5670
Threads: 28
Likes: 635 in 80 posts
Given Likes: 274
#11
09-23-2010, 03:22 AM
estimating handbook D.C. Fortuna, 1st ed. 1987
[Image: 95371975176779360384.jpg]
very old book, but i still use it on construction projects
it also have labor productivity tables (man-hour per quantity)
files: scanned jpg format files
pages 111-115
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 4 users Like RedHorse's post:4 users Like RedHorse's post
  â€¢ Dell_Brett, lirizen, ali akbar, concreteok
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,118
Likes: 30,986 in 4,091 posts
Given Likes: 612
#12
09-23-2010, 08:49 AM
Dear members 01 (hans01 and bus001)
Do you remeber, in our forum is forbiden to post (and to post links) for non english material. This forum is for all members and the forum is in english. At least you can specify the language. Better if you translate for all of us. As we wrote many times in the past use the PM to comunicate or to send links for foreign material.
  â€¢ RedHorse, Grunf, RANA WASEEM, oram
 RANA WASEEM
User ID: 10336
Threads: 102
Likes: 1,021 in 194 posts
Given Likes: 820
#13
09-26-2010, 08:00 AM
if you have used revit for steel detailing, you can get the steel tonnage easily by sung material takeoff and quantities...its that simple in REVIT STRUCTURE
WS
  â€¢
 lirizen
User ID: 28149
Threads: 0
Likes: 6 in 5 posts
Given Likes: 36
#14
09-29-2010, 02:29 AM
revit is powerful but need to do lots of detail drafting work, or is it a faster way of estimating steel tonnage?
  â€¢
 RANA WASEEM
User ID: 10336
Threads: 102
Given Likes: 820
#15
09-29-2010, 04:59 AM
dear lirizen
revit is powerful...yes it is...
but "nedd to do lots of detail drafting work"...i dont agree...so this was what your were already doing in AUTO CAD...but i would rather say...less drafting work needed in REVIT...for steel works its very easy even than concrete work...because in concrete you have to model rebars and get volume of concrete ...difficult task to model all bars...so anyway..but in steel there is no rebar so its a single step in REVIT SCHEDULE to get the volume and weight of steel members...unlike concrete members...
you just place a W section in model and there in schedule it automatically calculates the values required...or you can go to schedule and change the depth etc of member and in turn it changes in model....so see no "lot of drafting" needed...rather less drafting work required...
WS
  â€¢
 BennyP
User ID: 842
Threads: 1,118
Given Likes: 612
#16
09-29-2010, 07:47 AM
Do you remeber the initial question ?
Quote:For example contractor will do estimation of total steel tonnage of a factory base on architect layout, say 15ton/m² etc. inclusive column, rafter, etc. Or is there any estimation software or formula out there?
The question was how to estimate before and not how to finish detailed design and to totalize quantities.
  â€¢ RANA WASEEM
 leetse
User ID: 16712
Threads: 1
Likes: 38 in 7 posts
Given Likes: 19
#17
10-11-2010, 08:30 PM
Hello,
Some rules of thumb.
Single storey building lightweight roof covering up to 40m span (Rafters/Columns/Bracings/Purlins/Rails) = 27-30kg/m2.
Office buildings up to 5 storeys, Floor areas = 50kg/m2 , Roofs Areas = 35kg/m2.
Hospitals, heavy loadings and vibration considerations = 80kg/m2
The above are typical values and will give a rough estimate.
[-] The following 7 users Like leetse's post:7 users Like leetse's post
  â€¢ concreteok, Dell_Brett, RedHorse, RANA WASEEM, Grunf, lirizen, essenza
 lirizen
User ID: 28149
Threads: 0
Likes: 6 in 5 posts
Given Likes: 36
#18
10-16-2010, 02:12 AM
Just for sharing:
Badminton court
18m+18m+18m span (col-col) |^|^|^|
7.8 bay to bay (purlin-purlin) |-|-|-|-|-|-|-|-|
9 m column height
8 degree pitch roof
Design Criteria:
Metal roofing = 0.15 kN/m²
M&E loading = 0.15 kN/m²
Live Load = 0.25 kN/m²
Wind speed = 32m/s
RHS truss system :
Column+Truss+Purlin+Wall girth+Bracing = 19.10kg/m²
Portal Frame system:
Column+Truss+Purlin+Wall girth+Bracing = 24.00kg/m²
  â€¢
Threads: 840
Likes: 9,411 in 1,161 posts
#19
10-24-2010, 12:55 PM (This post was last modified: 10-24-2010, 12:59 PM by TAFATNEB.)
dear REDHORSE
you have posted the pages of a technical book that I deem useful, I'll be delighted if you could given the title of this book.
greeting
the software design and studies "staadpro, robotbat" automatically determine the exact quantity of elements in steel structure.
to determine exactly how much, the best tool is XTEEL, STRUCAD ...
  â€¢
 muralihare
User ID: 28976
Threads: 12
Likes: 64 in 12 posts
Given Likes: 16
#20
11-09-2010, 04:28 PM (This post was last modified: 11-09-2010, 04:31 PM by muralihare.)
Extracted from SCI PUBLICATION 178-Design for Construction
Typical tonnages for various types of building
Type of building Typical range of weight per Typical range of weight per
unit volume kg/m3 unit area kg/m2
Sheds (or halls)
Saw-tooth roof structures 4.6 to 7.2 30 to 47
Single bay buildings
with lattice girders 4.3 to 6.3 26 to 38
with roof trusses 4.2 to 6.0 25 to 36
Single bay portal-framed
buildings (w/o overhead crane) 4.8 to 7.2 31 to 47
buildings (with overhead crane) 6 to 10 60 to 100
Multi bay portal-framed
buildings (w/o overhead crane) 4.3 to 6.8 28 to 44
buildings (with overhead crane) 5.5 to 10 55 to 100
Special hall structures
(e.g. space frames) 5.5 to 10 44 to 80
Aeroplane hangars
(w/o overhead crane) 4.7 to 8.5 47 to 85
Aeroplane hangars
(with overhead crane) 6 to 11.5 60 to 115
Grandstands 5.1 to 10.5 51 to 105
Low rise (2 to 6 storeys) 9.0 to 12.8 36 to 51
Medium rise (7 to 12 storeys) 11.5 to 17.5 46 to 70
Car parks 8.9 to 16.3 31 to 57
Plant buildings
(w/o steel flooring) 7.8 to 10.9 70 to 98
(with steel flooring) 9.3 to 12.4 84 to 112
Heavy plant buildings
(e.g. BOS plants) 11.1 to 21.7 100 to 195
NOTES: Weights above include cold-formed and hot-rolled steelwork.
Weight comparisons per unit volume are more reliable indicators than weight per unit
area, hence the weights per unit area are simply derived from those per unit volume
using the typical heights.
Design studies can underestimate the weight of steel in the completed building by as
much as 30%.
sorry.i formed the above reply in table format .but it collapsed.
the first value (range) is "Typical range of weight perunit volume kg/m3"
the second value (range) is "Typical range of weight per unit area kg/m2"
[-] The following 1 user Likes muralihare's post:1 user Likes muralihare's post
  â€¢ lirizen
  The cost of Steel Structure around the World pezhmankhan 2 7,649 07-05-2017, 12:39 AM
Last Post: mtdingen
