Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Civil Engineerin Thesis [Msc & Phd]
Thread Closed
 parhyang
User ID: 25165
Threads: 30
Likes: 1,261 in 219 posts
Given Likes: 447
#11
11-21-2010, 02:44 PM (This post was last modified: 11-21-2010, 03:09 PM by parhyang.)
[Image: 61931987946394504800.png]
ABSTRACT
Several different approaches to determining second-order moments in plane frames were studied during this research. The focus of the research was to compare the moments predicted by four different commercially available computer analysis programs and the current design specification, the AISC LRFD moment magnification method. For this research, the second order moments for ten commonly designed frames were compared. An overview of various second-order analysis procedures is presented first. The solution procedure utilized by each computer program and the AISC moment magnification method are explained. Also, the frames considered in the research are described. Next the frames are analyzed and the results between each of the computer programs and the current design specifications are compared. Finally, conclusions are drawn concerning the consistency of the second-order moments predicted by each of the solution procedures and recommendations for their use are discussed. In general, each of the four computer analysis programs evaluated and the AISC moment magnification method can consistently and adequately predict the second-order moments in plane frames.
download directly,
[Image: 43001461383896370666.png]
Abstract
This thesis presents the methods utilized to model a steel deck truss bridge over the New River in Hillsville, Virginia. These methods were evaluated by comparing analytical results with data recorded from 14 members during live load testing. The research presented herein is part of a larger endeavor to understand the structural behavior and collapse mechanism of the erstwhile I-35W bridge in Minneapolis, MN. Objectives accomplished toward this end include investigation of lacing effects on built up member strain detection, live load testing of a steel truss bridge, and evaluating modeling techniques in comparison to recorded data.
Before any live load testing could be performed, it was necessary to confirm an acceptable strain gage layout for measuring member strains. The effect of riveted lacing in built-up members was investigated by constructing a two-thirds mockup of a typical bridge member. The mockup was then instrumented with strain gages and subjected to known strains in order to determine the most effective strain gage arrangement. Testing analysis concluded that for a built up member consisting of laced channels, one strain gage installed on the middle of the extreme fiber of each channel’s flanges was sufficient. Thus, laced members on the bridge were mounted with four strain gages each.
Data from live loads were obtained by loading two trucks to 25 tons each. Trucks were positioned at eight locations on the bridge in four different relative truck positions. Data were recorded continuously and reduced to member forces for model validation comparisons. Deflections at selected truss nodes were also recorded for model validation purposes.
The model validation process began by developing four simple truss models, each reflecting different expected restraint conditions, in the hopes of bracketing data from recorded results. Models were refined to frames, and then frames including floor beams and stringers for greater accuracy. The final, most accurate model was selected and used for a failure analysis. This model showed where the minimum amount of load could be applied in order to learn about the bridge’s failure behavior, for a test to be conducted at a later time.
download directly,
[-] The following 7 users Like parhyang's post:7 users Like parhyang's post
  • kowheng, Dell_Brett, jcoronellr, cappotchi, civilteam, malc, slowet
Pages (2): « Previous 1 2
