Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC - Steel Construction Manual
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
#11
08-18-2014, 11:23 AM
13 th Edition
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½
πŸ‘‰ CLICK HERE πŸ‘ˆ
@shanta
[-] The following 12 users Like ykhackhack's post:12 users Like ykhackhack's post
  β€’ blaze, Dell_Brett, Mohammad6299, eliseo.as, oanm2000, bigone, malc, PinkPant, jones, pedzaquino, kykin, psk62
 Ernest0
Nicaragua
User ID: 15083
Threads: 38
Likes: 1,155 in 60 posts
Given Likes: 204
#12
11-03-2014, 10:49 PM
AISC - Steel Construction Manual - 14th Edition
Author: AISC | Size: 46.6 MB | Format: PDF | Quality: Scanner | Publisher: American Institute of Steel Construction | Year: 2010 | pages: 2245
[Image: 67082233869452413621.jpg]
This Manual is the fourteenth major update of the AISC Steel Construction Manual, which was first published in 1927. Replacing the 13th Edition Manual, the 14th Edition Manual contains several updates and revisions, including the new HP18 and HP16 series, updated connection tables based on increased bolt shear strength values, revised single-plate and extended single-plate connection design procedures, enhanced prying action procedure, and a revised bracket plate design procedure. The most current printing of this publication is the second printing.
The following specifications, codes and standards are printed in Part 16 of this Manual:
2010 Specification for Structural Steel Buildings, including the new Chapter N on QC and QA, expanded composite design provisions, and improved slip-critical connection provisions
2009 RCSC Specification for Structural Joints Using High-Strength Bolts
2010 AISC Code of Standard Practice for Steel Buildings and Bridges
[-] The following 68 users Like Ernest0's post:68 users Like Ernest0's post
  β€’ engricardo, malc, carolinandra, Dell_Brett, yucapareja, inge911, RyanRS, tomtumx, Veggeta, gulilero, Mohammad6299, Hengki, pezhmankhan, dinu69in, amindoxiti, vardan, zrilek, simanta, f_slikken, Saze808, pontiac, bigone, learner20, jcbv, agelos100, Jackass, ranger, PinkPant, cace-01, dl4all, knrsa, ting tsai huang, eliseo.as, Diquan, milova, chrono146, nibbi, araza023, oanm2000, unix0123, jones, hector, icmrb7777, stldtls, ykhackhack, surajdas, trmpereira, sacem, engiman27, bridgeengineer, mecheil.edwar, englandboy, TAFATNEB, vvvv, pcaming, er.shyams, juanpa6, ESTRUCTO, rfireman, blaze, Sumatra, jik686, nickycruz, jaimeb316, ali akbar, atram, cabpcabp, sddcol
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
#13
12-31-2014, 04:07 AM (This post was last modified: 01-13-2015, 07:55 AM by BennyP.)
Use forum mandatory pasword to extract.
concrete solution advocate
[-] The following 34 users Like concreteok's post:34 users Like concreteok's post
  β€’ mecheil.edwar, amindoxiti, bigone, englandboy, TAFATNEB, zrilek, melekeen, jcbv, Dell_Brett, PinkPant, tomtumx, vvvv, simanta, pcaming, ingchio, er.shyams, juanpa6, oanm2000, Min Win, blaze, Sumatra, malc, inge911, ali akbar, atram, psk62, telecivil, faxel, angelarias, dak4482, oreslaw, Ekkaia, sacem, spat
 KMABD
User ID: 14195
Threads: 8
Likes: 682 in 36 posts
Given Likes: 111
#14
09-30-2016, 06:15 PM
Steel Construction Manual 14 ed. 4th Print
[Image: 31541088221630562561.png]
[Image: 92778089451278482935.png]
  • Author(s): AISC
  • Published By: AISC
  • Published Year: July 2015
  • Size: 271 MB
  • Quality: Scanner(OCR)
Good scan quality. Better than the one available as 2nd Print. File size is quite bigger though.
[-] The following 41 users Like KMABD's post:41 users Like KMABD's post
  β€’ sabooryan, temp1366, uncblue, Dell_Brett, tomtumx, Jackass, civilphongvan, isurya, pedzaquino, civilfafa, subin91, slowet, jcbv, shaker, zrilek, rezart, PinkPant, carolinandra, malc, concreteok, zainseiya, bridgeengineer, oanm2000, K.Lee, araza023, promo8, Ivan_1980, karthikeyans3d, Sumatra, alcalan57, simanta, zego2000, user, shanta, usman, fbx_rdnk, er.shyams, sddcol, spat, jacky899, raymelito
 Nita1391
User ID: 174964
Threads: 3
Likes: 465 in 38 posts
Given Likes: 700
#15
10-03-2018, 12:20 AM (This post was last modified: 10-04-2018, 11:25 AM by lisine. Edit Reason: Thread cleaned )
AISC 15thΒ  Steel Construction Manual
[Image: 69401305951358477674.jpg]
[Image: 23380033232349407502.jpg]
  • Author(s): AISC
  • Published Year: 2017
  • Size: 161 MB
  • Quality: Scanner-Low quality
  • Related Link:
  • Abstract: The 15th Edition Steel Construction Manual, first released in 2017, is the most current edition.
[-] The following 52 users Like Nita1391's post:52 users Like Nita1391's post
  β€’ Dell_Brett, simanta, tomtumx, jcbv, PinkPant, blaze, isurya, sabooryan, vvvv, rami1976, levanduy, Andrew seah, miquan, Hengki, dovsky, tuanpecc1, Richmond, pontiac, carolinandra, promo8, mtdingen, malc, jokerβ„’, ronnie_150, cargadory2k, wesam_19701970, sodapas, amareen2000, monter, oanm2000, munycamsec, zego2000, Ernest0, fbx_rdnk, harsono, stldtlr, rfireman, milova, zrilek, febo927, mahyarov, melekeen, eng donny, KMABD, K.Lee, ascetic19, mohamz, ejaner, jamildear4u, sacem, jonygut, kowheng
 tuanpecc1
Semi Senior Member
Vietnam
User ID: 16595
Threads: 62
Likes: 1,427 in 86 posts
Given Likes: 1378
#16
11-28-2018, 04:03 AM (This post was last modified: 11-28-2018, 04:55 AM by amindoxiti. Edit Reason: N/A )
This post has been made by CivilEA Post-Generator V2.3.1[/align]
[/align]
[-] The following 39 users Like tuanpecc1's post:39 users Like tuanpecc1's post
  β€’ zrilek, PinkPant, levanduy, rendel_Β©, Nita1391, cace-01, avge, gulilero, Aviator, febo927, oanm2000, promo8, melekeen, temp1366, mgdario, jcbv, malc, pram, muralihare, eng donny, agelos100, karthikeyans3d, Wijono, Dell_Brett, apocalipse, K.Lee, pedzaquino, Limpias72, munycamsec, lasalleguy, jamildear4u, sacem, jacky899, simanta, jonygut, tolesa54, sodapas, spat, blaze
 Nita1391
User ID: 174964
Threads: 3
Given Likes: 700
#17
12-07-2019, 07:37 PM
Hi
Here is Very good quality version of this book only 67 MB
Selected Page to view
Download
[-] The following 28 users Like Nita1391's post:28 users Like Nita1391's post
  β€’ haze, CAMSECT, carolinandra, subin91, usman, milova, amindoxiti, malc, sabooryan, jcbv, zrilek, pontiac, pedzaquino, shaker, juangpulidoc, PinkPant, caifan, febo927, oanm2000, Dell_Brett, mtdingen, gulilero, KhaLed-S.E, araza023, KMABD, babakfeyzi, sodapas, chrono146
 malc
User ID: 30599
Threads: 65
Likes: 1,520 in 155 posts
Given Likes: 15191
#18
03-07-2020, 09:10 PM
You will find the requested pages on post #2 Please download from there.
[-] The following 2 users Like malc's post:2 users Like malc's post
  β€’ KMABD, PinkPant
Threads: 274
Likes: 12,075 in 1,233 posts
09-23-2020, 06:07 AM
The two missing pages (6-108 and 6-109) are added from scanned filed and their quality a little improved by photoshop.
[-] The following 9 users Like pezhmankhan's post:9 users Like pezhmankhan's post
  β€’ blaze, jcbv, PinkPant, chandra1234567, subin91, oanm2000, temp1366, zrilek, Dell_Brett
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
#20
01-05-2022, 12:41 PM
[-] The following 9 users Like usman's post:9 users Like usman's post
  β€’ frank1972, KMABD, jcbv, simanta, Administrator , kowheng, Dell_Brett, temp1366, PinkPant
  AISC - Steel Design Guides Administrator 75 87,818 06-13-2026, 09:38 AM
  AISC 327: Seismic Design Manual weichunc 16 15,416 06-13-2026, 09:27 AM
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 13,182 08-18-2025, 07:07 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,761 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 3,346 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 3,160 12-04-2023, 09:17 AM
  AISC: Facts for Steel Buildings tarugo 8 9,118 12-04-2023, 09:11 AM
