06-11-2012, 07:27 PM
06-11-2012, 08:23 PM
Upper bound solution for ultimate bearing capacity with a modified HoekβBrown failure criterion
Xiao-Li Yang,Jian-Hua Yin International Journal of Rock Mechanics and Mining Sciences Volume 42, Issue 4, June 2005, Pages 550β560 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Thanks
06-14-2012, 09:01 AM
* New coatings for the corrosion protection of steel pipelines and pilings in severely aggressive environments
George M. Harris, Alan Lorenz The Tapecoat Company, 1527 Lyons Street, P.O. Box 631, Evanston, IL 60204-0631, U.S.A. Available online 25 April 2003. Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π ** Assessment of stress corrosion cracking and hydrogen embrittlement susceptibility of buried pipeline steels A.H.S. Bueno,B.B. Castro,J.A.C. Ponciano (2008) Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π *** Change of physicochemical parameters of soils near stress-corrosion defects on gas pipelines S.K. Zhigletsova el al. Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Pipes, pipeline construction and valves Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
06-14-2012, 06:50 PM
(06-14-2012, 09:01 AM)mary Wrote:All 4 documents are archived here:
I need this for my research. Please share
Nonlinear instability of angle section beams subjected to static and dynamic sudden step loads Wei-bin Yuan Journal of Constructional Steel Research, Volume 77, October 2012, Pages 19β22 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
06-17-2012, 09:25 PM
step loads Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
06-24-2012, 06:36 PM
Hi guys, can you provide me this paper? thanks in advance.
Structural optimization using equivalent static loads at all time intervals - W.S Choi, G.J Park Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
06-24-2012, 08:19 PM
07-14-2012, 08:55 AM
Hi, I need these paper:
Giancarlo Dal Moro, Fabrizio Ferigo Joint analysis of Rayleigh- and Love-wave dispersion: Issues, criteria and improvements Journal of Applied Geophysics Volume 75, Issue 3, November 2011, Pages 573β589 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Thanks. |
