06-04-2011, 02:20 PM
Dear all member,
l m looking for this ASTM. Thanks
Dear all member,
06-05-2011, 01:42 PM
Dear all member,
Looking for this ASTM. Thanks
06-21-2011, 04:48 AM
Dear All,
If you had the following ASTM section please share it with us. ASTM D1195/D1195M-09 Standard Test Method for Repetitive Static Plate Load Tests of Soils and Flexible Pavement Components, for Use in Evaluation and Design of Airport and Highway Pavements. Many thanks in advance. Cheers, Didie
Hi Civileans,
I need: - LUM.D.2, In-situ stress tests on masonry based on the flat jack, 1991 - LUM.D.3, In-situ strength/elasticity tests on masonry based on the flat-jack, 1990 from RILEM book: RILEM Recommendations for the Testing and Use of Constructions Materials, 1994. and - ASTM, In-situ compressive stress within solid unit masonry estimated using flat-jack measurements, ASTM Standard C 1196-91, 1991 - ASTM, In-situ measurement of masonry deformability properties using flat-jack method, ASTM Standard C 1197-91, 1991 If anyone has this, please share it.
07-12-2011, 12:23 PM
Please help me to find
ASTM D2573 - 08 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Thanks in advance!
07-14-2011, 09:53 AM
Dear All,
Please help me to find ASTM 6067-10. Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Thanks in advance!
07-18-2011, 10:41 PM
Dear all,
Can you please upload the ASTM 7176? I need it for my work. Thank you.
07-31-2011, 04:17 PM
Hi dudes
ASTMC230-90,Standard speciο¬cation for ο¬ow table for use in tests of hydraulic cement,Annual book of ASTM standards,vol.04.02.3.American Society for Testing and Materials I will appreciate if any body can help me by providing this code for me
08-03-2011, 05:15 AM
ASTM D3740 - 10 Standard Practice for Minimum Requirements for Agencies Engaged in Testing and/or Inspection of Soil and Rock as Used in Engineering Design and Construction
08-16-2011, 02:36 AM
Dear Members,
ASTM F1145 - 05(2011) Standard Specification for Turnbuckles, Swaged, Welded, Forged Abstract This specification covers swaged welded, cast, or forged turnbuckles with and without jam nuts. A turnbuckle is an internally threaded loop or sleeve intended for assembly with a threaded stud, eye, hook, or jaw at each end, used for applying tension to rods, wire rope, and so forth. Turnbuckles shall be of the following types and grades: Type I (forged, spread, resistance welded and arc or gas welded); Type II; and Type III. Turnbuckles shall be of the following classes; Class A; Class B; Class C; Class D; Class E; Class F; Class G; and Class H. The following tests shall be performed: proof test; breaking strength test; bending test; and galvanizing test. Please share ASTM F1145 - 05(2011)! Anyway is there any TIS or other standard similar to ASTM F1145? Best regards, rkce |
| Possibly Related Threads… | |||||
| Thread | Author | Replies | Views | Last Post | |
| [REQUEST] ASTM E1300-12ae1? Glass Design | Garylam1029 | 3 | 3,312 |
07-30-2019, 04:48 AM Last Post: concreteok |
| [REQUEST] ASTM D4694 - 09(2015): Standard Test Method for Deflections with a FWD type | utan | 2 | 2,479 |
01-20-2018, 08:10 AM Last Post: ir_71 |
| [REQUEST] ASTM D1143/D1143M - 07 Standard Test Methods for Deep Foundations Under Static Axial | scml2003 | 2 | 3,017 |
03-09-2017, 12:27 AM Last Post: tomtumx |
| [REQUEST] ASTM 2015 Annual Book | abualamal | 0 | 1,707 |
10-10-2015, 03:34 PM Last Post: abualamal |
| [REQUEST] ASTM A706 / A706M - 14 | aslam | 0 | 1,755 |
11-26-2014, 03:43 PM Last Post: aslam |
| [REQUEST] ASTM D-290 -91a and AASHTO T-172 | ervikas34 | 0 | 1,530 |
10-16-2014, 01:15 AM Last Post: ervikas34 |
| [REQUEST] (ASTM STP702) Full-Scale Load Testing of Structures | apocalipse | 0 | 1,657 |
08-19-2014, 08:59 PM Last Post: apocalipse |
