11-12-2009, 04:23 PM
Is anybody using structural software and autocad on windows 7? Are there any problems?
Thanks
Thanks
Thanks
11-12-2009, 04:52 PM
(11-12-2009, 04:23 PM)haze Wrote: Is anybody using structural software and autocad on windows 7? Are there any problems? no problems with recent versions of following softwares,, Autocad, staad pro, sap2000, struds, adapt PT, etabs, 3ds MAX, revit Architecture, Revit Structure, STRAP. all these s'wares are working with me, in x64 win 7. & will definitely work with 32 bit also. if u wanna use any other s'ware, our forum members will help u. regards, NIKI102
INCREDIBLE INDIA
The following 7 users Like niki102's post:
• concreteok, Grunf, levanduy, Dell_Brett, Administrator , jaks, oanm2000
11-14-2009, 03:34 AM
In addition to the programs niki is running I am running all the RISA programs, most of the current RAM programs, autocad 2010, Enercalc, and Mathcad 14. I have not run into a program that I can not run w/ windows 7 64 bit.
Worst case scenario..... if you come across a program you can not run, run it in a virtual machine with the OS of your choice.
11-17-2009, 02:15 PM
SCADDS/Nucleus RC 2007 which is a rcc designing software works on windows 7
11-20-2009, 06:25 PM
(11-12-2009, 04:23 PM)haze Wrote: Is anybody using structural software and autocad on windows 7? Are there any problems? No. I dont see any problem running the structural analysis program under Windows 7. Even it has problem, you can change the compatibility to either Windows xp or Vista if you like.
08-13-2010, 09:17 AM
I get the following deviation of results in SAP2000 v14.2 Verification
Code: ***************************************
The ONLY dumb question is one that is not asked
09-03-2010, 04:18 AM
I'n using both the Civil 3D 2010 and Civil 3D 2011 on Windows 7 x64 and I have no issues. The 2010 runs in 32 bit compatibility mode while the 2011 is x64 built so I run it natively.
Possibly Related Threads… | |||||
Thread | Author | Replies | Views | Last Post | |
Install Windows XP on A Machine Already Running Windows Vista OR Windows 7 | chigozie | 4 | 6,603 |
07-17-2010, 01:06 PM Last Post: BennyP |
