Civil Engineering Association Software Software Product Bentley Products Bentley Microstation GEOPAK Survey XM Edition 08.09.07.28
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
03-27-2009, 04:05 PM
General Description :
Created for professional surveyors, GEOPAK Survey handles all surveying needs in a field-to-finish environment. The software utilizes raw field data in virtually any data format to perform
geodetic conversions and powerful feature mapping in a graphical environment. An easy, wizard-like Survey Project Manager interface guides you through the workflow and an extensive feature library automates symbology, annotation and connectivity. Customizable feature management makes it easy to include or eliminate DTM data. GEOPAK Survey exports data to the collector for stakeout, including proposed horizontal and vertical design and cross sections. GEOPAK Survey is fully customizable. Double-precision calculations and integration with other civil disciplines make GEOPAK Survey the ideal surveying application in the MicroStation environment.
162 MB
[-] The following 5 users Like robertsas's post:5 users Like robertsas's post
  â€¢ piyush2678, piyush2678, zrilek, zrilek, hadeest
  Bentley MicroStation 2024 poolmand 0 3,227 10-05-2024, 10:18 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,404 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 22,878 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 4,985 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  Bentley OpenRail Designer CONNECT Edition 2021 poolmand 1 4,330 02-26-2022, 09:13 AM
  Bentley OpenRoads Designer CONNECT Edition 2021 poolmand 0 3,948 02-23-2022, 10:08 AM
  Bentley RAM Elements CONNECT Edition V16 Update 5 v16.05.00.213 x64 poolmand 0 4,632 11-23-2021, 07:08 AM
