02-23-2010, 08:11 AM
Autodesk Subscription 2010 MegaPack Multilanguage (21.02.2010)
Autodesk Subscription 2010 MegaPack Multilanguage (21.02.2010) | 10.23 GB
Unique collection of all available in early 2010 additions, called Subscription Pack's, available to subscribers only licensed Autodesk Inc.
Year: 2010
Version: 2010
Developer: Autodesk Inc
Platform: Microsoft Windows XP & Vista & 7
Language: Multilingual
Tabletka: Not required
List of Additions:
ArchVision RPC Content for AutoCAD Architecture 2010 and AutoCAD MEP 2010
AutoCAD Land Desktop Style Converter Extension for AutoCAD Civil and Civil 3D 2010
AutoCAD Map 3D 2009 & 2010 - Industry Toolkits for Water, Wastewater & Electric Utilities
AutoCAD MEP 2010 - Plug-in for DIALux
Autodesk ® 3ds Max ® CAT for 3ds Max 2010
Autodesk FDO Provider for Autodesk Topobase 2010
Autodesk MapGuide Studio 2010
Batch Print for Autodesk Revit 2010
Connection Extension for 3ds Max 2010
Connection Extension for 3ds Max Design 2010
GENIO Import / Export Extension for AutoCAD Civil and Civil 3D 2010
Globe Link for Autodesk Revit 2010
Space Naming Utility for Revit MEP 2009 & 2010
Stage Storage Extension for AutoCAD Civil 3D 2010
Subscription Advantage Pack for AutoCAD 2010
Subscription Advantage Pack for AutoCAD Architecture 2010
Subscription Advantage Pack for AutoCAD Civil 3D 2010
Subscription Advantage Pack for AutoCAD Map 3D 2010
Subscription Advantage Pack for AutoCAD Mechanical 2010
Subscription Advantage Pack for AutoCAD MEP 2010
Subscription Advantage Pack for AutoCAD P & ID 2010
Subscription Advantage Pack for Autodesk Inventor 2010
Subscription Advantage Pack for Autodesk Navisworks 2010
Subscription Advantage Pack for Autodesk Revit Architecture 2010
Subscription Advantage Pack for Autodesk Revit MEP 2010
Subscription Advantage Pack for Autodesk Revit Structure 2010
Subscription Structural Library for Autodesk Revit Structure 2010
Subscription Advantage Pack for Autodesk Showcase 2010 R1
Worksharing Monitor for Autodesk Revit 2010
Library to Autodesk Revit MEP 2010 for Russia and CIS
Package add-on modules for subscribers AutoCAD 2010
Package add-on modules for subscribers AutoCAD Architecture 2010
Package add-on modules for subscribers AutoCAD Civil 3D 2010
Package add-on modules for subscribers AutoCAD Map 3D 2010
Package add-on modules for subscribers AutoCAD Mechanical 2010
Package add-on modules for subscribers AutoCAD MEP 2010
Package add-on modules for subscribers AutoCAD P & ID 2010
Package add-on modules for subscribers Autodesk Inventor 2010
Package add-on modules for subscribers Autodesk Navisworks 2010
Package add-on modules for subscribers Autodesk Revit Architecture 2010
Package add-on modules for subscribers Autodesk Revit MEP 2010
Package add-on modules for subscribers Autodesk Revit Structure 2010
Expanding Russian Content Extension for AutoCAD MEP 2010
Expanding Russian Content Extension for Autodesk Revit Architecture 2010
Added on 21/02/2010::
Package add-on modules for the Russian subscribers AutoCAD 2010
Package add-on modules for the Russian subscribers AutoCAD Architecture 2010
Package add-on modules for the Russian subscribers AutoCAD Civil 3D 2010
Package add-on modules for the Russian subscribers AutoCAD Map 3D 2010
Package add-on modules for the Russian subscribers AutoCAD Mechanical 2010
Package add-on modules for the Russian subscribers AutoCAD MEP 2010
Package add-on modules for the Russian subscribers AutoCAD P & ID 2010
Package add-on modules for the Russian subscribers Autodesk Inventor 2010
Package add-on modules for the Russian subscribers Autodesk Navisworks 2010
Package add-on modules for the Russian subscribers Autodesk Revit Architecture 2010
Package add-on modules for the Russian subscribers Autodesk Revit MEP 2010
Package add-on modules for the Russian subscribers Autodesk Revit Structure 2010
by kamran !
Kamran via HP :)
