UBC - IBC Comparison
This helpful tool provides a comparative analysis between the structural provisions of the 1997 Uniform Building Code and the 2000 International Building Code with a cross reference directory. Code sections, tables and figures from the IBC are listed sequentially with an analysis of comparison to the UBC which can be used as a plan checking and field inspection aid. Readers can also locate IBC section numbers for similar provisions found in the UBC and transition them to the IBC.
Please try this link :
π CLICK HERE π
![[Image: 62826052202112060985.jpg]](https://pic.civilea.com/images/62826052202112060985.jpg)
![[Image: 87325566360224796932.jpg]](https://pic.civilea.com/images/87325566360224796932.jpg)
