Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) IABSE: Structural Bearings and Expansion Joints for Bridges
Threads: 307
12-30-2009, 08:35 AM (This post was last modified: 12-16-2011, 09:16 PM by usman.)
Structural bearings and expansion joints for bridges
[Image: 32746970005230835835.jpg]
GΓΌnter Ramberger; Professor, Technical University, Vienna, Austria
89 pages and 131 illustrations, in English
Format: 170 x 240 mm
ISBN 3857481056
Published: May 2002
This book is aimed at both students and practicing engineers, working in the field of bridge design, construction, analysis, inspection maintenance and repair.
Contents
Bridge superstructures have to be designed to permit thermal and live load strains to occur without unintended restraints. Bridge bearings have to transfer forces from the superstructure to the substructure, allowing all movements in directions defined by the designer. The two functions - transfer the loads and allow movements only in the required directions for a long service time with little maintenance - are not so easy to fulfill. Different bearings for different purposes and requirements have been developed so, that the bridge designer can choose the most suitable bearing.
By the movement of a bridge, gaps are necessary between superstructure and substructure. Expansion joints fill the gaps, allowing traffic loads to be carried and allowing all expected displacements with low resistance. Expansion joints should provide a smooth transition, avoid noise emission as far as possible and withstand all mechanical actions and chemical attacks (de-icing) for a long time. A simple exchange of all wearing parts and of the entire expansion joint should be possible.
The present volume provides a comprehensive survey of arrangement, construction and installation of bearings and expansion joints for bridges including calculation of bearing reactions and movements, analysis and design, inspection and maintenance. A long list of references deals with the subjects but also with aspects in the vicinity of bearings and expansion joints.
[-] The following 32 users Like Grunf's post:32 users Like Grunf's post
  β€’ bus001, kowheng, Dell_Brett, oanm2000, jocagalhao, baikur, subin91, avscorreia, samranda, pezhmankhan, Josep Soroz, adi04, di_si, Milkshake, rudyhera03, jf28, bsghai, ruaumoko, gelbert, blaze, monter, z_reticula, adshrt, carolinandra, vvvv, zrilek, i_kabir, fun113113, rkce, ladjin, mecheil.edwar, bhawk0
Threads: 57
04-19-2011, 06:10 AM (This post was last modified: 02-25-2013, 12:55 AM by kowheng.)
Multiple-bookmarked PDFs|RAR 4.19|3.69 MB
RAR password: KCivilEA
[-] The following 16 users Like kowheng's post:16 users Like kowheng's post
  β€’ malc, vvvv, blaze, ssobhan, zrilek, seriousboy, Grunf, orambo, buraz, andtangh, ladjin, mecheil.edwar, bhawk0, Dell_Brett, slowet, chenamoy
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-24-2013, 08:56 PM
regards
[-] The following 8 users Like arshiakh's post:8 users Like arshiakh's post
  β€’ hignacio43, jcbv, ting tsai huang, gulilero, knrsa, Dell_Brett, peixoto, ruaumoko
  IABSE: Cable-Stayed Bridges - Past, Present and Future toa011 2 3,875 02-06-2016, 08:34 AM
Last Post: taifur
  Bridge Bearings and Expansion Joints - by David J Lee triance 3 5,010 12-11-2015, 12:42 PM
  Bridge and highways expansion joints rami1976 0 1,610 10-17-2015, 11:46 PM
  Design rules for bridge bearings and expansion joints mahyarov 2 3,032 12-05-2014, 10:00 PM
Last Post: monter
  IABSE: Foundations for Major Bridges: Design and Construction lamkin 2 4,412 07-30-2013, 09:07 AM
Last Post: Jackass
  Structural Bearings - by H Eggert, W Kauschke lamkin 4 4,238 05-27-2013, 09:36 PM
Last Post: monter
  IABSE: Cable Vibrations in Cable-Stayed Bridges epee 3 3,381 03-18-2013, 02:13 PM
