Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive as1170 requested by legarleon
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
12-06-2009, 01:26 PM
please check is AS1170.1 for structural glass is in the list, please share, thanks.
The new glass design approach used in Australian standard, AS1288
Dr Ignatius Calderone, Director, Calderone and Associates Pty Ltd.
There is a trend for glass designers around the world to make reference to standards from other countries. Therefore, in order to avoid improper use of the new Australian standard, it is important that the rationale used and the limitations of the standards are well understood. This paper presents the methodology used in developing the new design charts used in the revised Australian Standard, AS1288, which was published on 16 January 2006. The change to ultimate limit state design in the Australian wind loading code necessitated the corresponding upgrading of the wind loading charts in AS1288. The new charts are also an improvement on the old charts, with the inclusion of criteria such as the aspect ratio and slenderness factor. Separate charts are given for each glass type and thickness.As well as covering the rationale behind the new ultimate limit state design stresses used in the new charts, comparisons are made with the previous Australian code requirements and other existing and draft international standards. These comparisons will highlight the dangers of improperly using a 50-year return wind loading with the new Australian design code, which is applicable to 1000-year return period wind loads.
please check the above code and kindly upload for sharing. thanks
concrete solution advocate
 Alexander
User ID: 5365
Threads: 5
Likes: 59 in 16 posts
Given Likes: 114
02-03-2010, 10:44 PM
For information, these are the titles of the various AS 1170 codes:
AS/NZS 1170.0 - Structural Design Actions (General Principle)
AS/NZS 1170.1 - Structural Design Actions (Permanent, Imposed and other actions)
AS/NZS 1170.2 - Structural Design Actions (Wind Actions)
AS/NZS 1170.3 - Structural Design Actions (Snow and Ice actions)
AS 1170.4 - Structural Design Actions (Earthquake actions in Australia)
Hope this helps
  [REQUEST] Australian Standard AS1170.4-2007 pohpo 1 1,839 04-02-2013, 11:34 AM
Last Post: pezhmankhan
  [REQUEST] BS EN 12046,12051,12217,13241 & 13724 requested vpmohammed 3 2,488 11-23-2011, 03:12 AM
Last Post: mybest
  [REQUEST] AS1170.4-1993 jmpkumara 3 2,677 11-03-2010, 01:45 PM
Last Post: jmpkumara
