Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Single Piles and Pile Groups Under Lateral Loading
 viva_60_ae
User ID: 6373
Threads: 17
Likes: 484 in 29 posts
Given Likes: 62
05-11-2010, 09:12 AM (This post was last modified: 05-11-2010, 11:24 AM by Grunf.)
[Image: 09759987111937982711.jpg]
Lymon C. Reese (Author), Willem van Impe (Author)
Hardcover: 480 pages
Publisher: Taylor & Francis; 1 edition (January 1, 2000)
ISBN-10: 9058093409
ISBN-13: 978-9058093400
Product Description
The complexities of designing piles for lateral load are mainfold. Wind forces act against overhead signs and high rise buildings and loads from waves and currents are frequently critical to the design of offshore structures and bridges. Waterfront structures must support horizontal loads from the berthing of ships, retaining walls must withstand lateral earth pressures. Such structures are often founded on piles which may be steel pipes or reinforced concrete columns. In navigating the complexities of lateral-load design, the book presents procedures for designing the piles and pile groups; a problem that can only be solved by accounting for the soil resistance as related to the lateral deflection of the pile.
This book guides the designer into finding the critical loads, either causing a pile to be overloaded or causing too much lateral deflection. Complex equations are derived and explained, and computer programs are used to solve the equations. Simplified versions of the two required programs are presented on a CD-ROM, allowing the reader to check the solution of some of the many examples given in the book and to find answers to related problems. Applications of the method are presented for the design of piles for a building, an offshore structure, an overhead sign, etc.
Edit reason: Post was duplicated, as well the link was duplicated so the link is deleted, but the post is still here because of the book info and cover. (G)
[-] The following 33 users Like viva_60_ae's post:33 users Like viva_60_ae's post
  β€’ samik, NAUTILUS87, robertsas, Dell_Brett, levanduy, kowheng, chigozie, lamkin, sintflut, zrilek, ravisbassi, hapsea, ilgar, oram, oanm2000, shanta, Panjack39, psycin, mecheil.edwar, Evandrojr, cigutierrezg, monter, Sumatra, tonmjr, gulilero, ELAHI1979, LiviuM, alibouafia, nhim4mat2006, yutt, vvvv, K.Lee, tuanpecc1
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
11-20-2010, 02:20 PM
[-] The following 36 users Like Dell_Brett's post:36 users Like Dell_Brett's post
  β€’ Grunf, chigozie, ravisbassi, Petrit, ilgar, robertsas, rezart, oanm2000, ruaumoko, shanta, elsokary, Panjack39, isurya, wanazri, thanhthan, kevin8107, mahfuzbangla, IzzyCole, tomcat007, psycin, mecheil.edwar, blaze, jayborre, Jackass, cigutierrezg, nigema, henrycv, civiea_civiea, simanta, vkkr, YeiYei, Sumatra, tonmjr, foxxx2010, shadabg, yutt
Threads: 57
07-03-2011, 04:17 AM (This post was last modified: 12-23-2011, 09:15 AM by kowheng.)
PDF|RAR 36.79|32.63 MB
RAR password: KCivilEA
[-] The following 16 users Like kowheng's post:16 users Like kowheng's post
  β€’ malc, Dell_Brett, oanm2000, cigutierrezg, jcaz15, Sumatra, fashion, peymanlord, 3fan, tonmjr, mahyarov, chrono146, julioreptil, ting tsai huang, shadabg, milova
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
12-21-2011, 10:26 AM
[Image: password.png].
[-] The following 1 user Likes 3fan's post:1 user Likes 3fan's post
  β€’ henrycv
Threads: 154
08-18-2012, 08:25 AM
[-] The following 8 users Like shadabg's post:8 users Like shadabg's post
  β€’ Dell_Brett, psk62, gulilero, peixoto, pmg814, LiviuM, harsono, rusty
 i_kabir
Bangladesh
User ID: 741
Threads: 122
Likes: 3,231 in 259 posts
Given Likes: 446
07-14-2014, 06:49 AM
Single Piles and Pile Groups Under Lateral Loading (2nd Edition)
Author: Lymon C. Reese, William F. Van Impe | Size: 16.4 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2011 | pages: 343 | ISBN: 97804I5469883
[Image: 97754989770439585919.jpg]
Features
> Homework problems with solution aids offered by the student version of the software
> New case studies and updated case studies utilizing modern methods of characterizing soil properties
Summary
The complexities of designing piles for lateral loads are manifold as there are many forces that are critical to the design of big structures such as bridges, offshore and waterfront structures and retaining walls. The loads on structures should be supported either horizontally or laterally or in both directions and most structures have in common that they are founded on piles. To create solid foundations, the pile designer is driven towards finding the critical load on a certain structure, either by causing overload or by causing too much lateral deflection.
This second edition of Reese and Van Impe’s course book explores and explains lateral load design and procedures for designing piles and pile groups, accounting for the soil resistance, as related to the lateral deflection of the pile. It addresses the analysis of piles of varying stiffness installed into soils with a variety of characteristics, accounting for the axial load at the top of the pile and for the rotational restraint of the pile head. The presented method using load-transfer functions is currently applied in practice by thousands of engineering offices in the world. Moreover, various experimental case design examples, including the design of an offshore platform pile foundation are given to complement theory. The rich list of relevant publications will serve the user into further reading.
Designed as a textbook for senior undergraduate/graduate student courses in pile engineering, foundation engineering and related subjects, this set of book and CD-ROM will also benefit professionals in civil and mining engineering and in the applied earth sciences.
[Image: comments.png]
To download Errata updated on September 13, 2012 visit:
[-] The following 28 users Like i_kabir's post:28 users Like i_kabir's post
  β€’ Mohammad6299, Andrew seah, malc, cace-01, viet2010, zrilek, subin91, shadabg, mary, gulilero, ting tsai huang, blaze, alibouafia, TAFATNEB, ruaumoko, simanta, miquan, bigone, manzoor_quadri, dinu69in, pram, promo8, Evandrojr, er.shyams, nhim4mat2006, bridgeengineer, vvvv, rizal13
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
07-14-2014, 07:20 AM
[-] The following 7 users Like cace-01's post:7 users Like cace-01's post
  β€’ shadabg, isurya, TAFATNEB, blaze, bigone, draluka, nhim4mat2006
 avscorreia
Portugal
User ID: 2747
Threads: 9
Likes: 762 in 203 posts
Given Likes: 875
07-14-2014, 08:03 AM
A lot of pages are missing in the 2nd Edition. It seems that some chapter parts were not binded together when the pdf was created. Is it possible to upload the complete book?
Thanks.
[-] The following 9 users Like avscorreia's post:9 users Like avscorreia's post
  β€’ Dell_Brett, PinkPant, zrilek, TAFATNEB, apocalipse, bigone, hazus, durden, nhim4mat2006
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
05-04-2015, 12:57 PM
PinkPant
[-] The following 23 users Like PinkPant's post:23 users Like PinkPant's post
  β€’ rezart, hatkam, amindoxiti, gulilero, oanm2000, geomahesh, promo8, ykhackhack, Evandrojr, shadabg, cristi, malc, er.shyams, blaze, cace-01, simanta, nhim4mat2006, pram, bridgeengineer, Rainbow, rizal13, erthqkengnrβ„’, versiondemo
 camto2
Cambodia
User ID: 88877
Threads: 35
Likes: 1,240 in 101 posts
Given Likes: 106
#10
02-22-2018, 07:33 AM
new link:
[-] The following 16 users Like camto2's post:16 users Like camto2's post
  β€’ RajaK, Andrew seah, vvvv, febo927, Trishu999, promo8, usman, K.Lee, Dell_Brett, tuanpecc1, shadabg, pedzaquino, mgdario, oanm2000, rizal13, Hengki
  Design of Piles Under Cyclic Loading: SOLCYP Recommendations OSHO 0 1,866 06-22-2019, 12:42 AM
Last Post: OSHO
  Piles and Pile Foundations cace-01 5 4,177 05-04-2015, 12:50 PM
Last Post: PinkPant
  CENTRIFUGE MODELING OF LATERALLY LOADED BATTERED PILE GROUPS IN SAND mahyarov 0 1,584 10-28-2012, 06:15 AM
Last Post: mahyarov
  THE RESPONSE OF PILES DURING EARTHQUAKES: DYNAMIC SOIL-PILE-SUPERSTRUCTURE INTERACTIO mahyarov 0 1,717 10-28-2012, 06:12 AM
Last Post: mahyarov
  The Effect of Surcharge Loading Adjacent to Piles elitvdis 4 3,752 08-07-2012, 07:39 AM
Last Post: shadabg
  NCHRP R461: Static and Dynamic Lateral Loading of Pile Groups SR71 4 3,796 07-16-2012, 05:34 AM
Last Post: shadabg
  Driven Piles are Tested Piles isurya 2 3,130 06-27-2011, 04:38 AM
