DESIGN GUIDE FOR HIGH STRENGTH CONCRETE TO SINGAPORE STANDARD
![[Image: 61724343225433605343.jpg]](https://pic.civilea.com/images/61724343225433605343.jpg)
This design guide serves to extend the use of concrete beyond Grade 60 in the design of concrete structures using CP65. Hence, it is intended for use by engineers familiar with the design of concrete structures using particularly CP65 but who have little or no experience of high strength concrete (HSC). The guide is intended to provide safe design guidance, based on the best available information, especially in the areas not adequately covered by CP65.
In this respect, the guidance and recommendations in the Concrete Society Technical Report 49 are very relevant and have been extensively adopted here where ever possible. However, it should be noted that this guidance deals only with HSC made with normal weight aggregates and it should not be use for light weight aggregate concrete.
Download Links:
