Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] IEEE 1863-2024 Approved Draft Guide for Overhead Alternating Current (AC) Transmisson
[Request] IEEE 1863-2024 Approved Draft Guide for Overhead Alternating Current (AC) Transmisson
 civilfafa
Iraq
User ID: 174183
Threads: 49
Likes: 305 in 51 posts
Given Likes: 459
07-11-2024, 08:08 AM
IEEE Approved Draft Guide for Overhead Alternating Current (AC) Transmission Line Design (2024)
Related Link:
Published date : 2024-03-01
Abstract: This Guide covers basic principles, methods and experience for designing of 110 kV to 1000 kV AC overhead transmission lines, and may also be used as reference for the design of lower voltage overhead transmission lines. This Guide consists of the introduction, definitions, meteorological design criteria, electrical design, structural design criteria, design of foundations, and experiment result and design experience. This Guide is a listing of the information and procedure that is required during the design of AC transmission line, and provides guidance for transmission line designers in data collection and design stage.
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,712 in 1,306 posts
Given Likes: 4629
07-12-2024, 10:06 AM
IEEE 1863-2019
Not the 2024 version but maybe it will help.
[-] The following 1 user Likes lisine's post:1 user Likes lisine's post
  • civilfafa
 civilfafa
Iraq
User ID: 174183
Threads: 49
Given Likes: 459
07-12-2024, 09:52 PM (This post was last modified: 07-12-2024, 09:52 PM by civilfafa.)
Hi,
I had 2019 version and hoped you may have 2024 revision.
Regardless, thanks for sharing the one you had.
Cheers.
  [REQUEST] IEEE 1127-2023-Guide for the Design, Construction, and Operation of Electric Power civilfafa 0 1,228 11-01-2025, 08:00 AM
Last Post: civilfafa
  [REQUEST] IEEE 605-2023 Guide for Bus Design in Air Insulated Substations civilfafa 1 3,264 11-16-2024, 07:08 AM
  [REQUEST] IEEE 2954-2023 IEEE Recommended Practice For Overhead Transmission Line Design civilfafa 1 1,898 06-18-2024, 06:56 AM
  [REQUEST] P751 - IEEE Draft Guide for Wood Structures Used for Overhead Electric Transmission L civilfafa 0 1,475 06-17-2023, 02:23 AM
  [REQUEST] ASTM and IEEE Standards lisine 1 1,915 03-17-2021, 09:52 PM
Last Post: fordcell
