Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
01-17-2024, 07:27 AM
ACI PRC-526-19: Guide for Design and Construction with Autoclaved Aerated Concrete Panels
Author(s)/Editor(s): ACI Committee 526| Format: PDF| Year: 2019| pages: 82 | ISBN: 9781641950657
[Image: 13156512928984793150.jpg]
This guide is intended for use by architects, engineers, contractors, building officials, and manufacturers. Its purpose is to present, in a single source, information that can help those individuals design, specify, and construct with factory-reinforced panels of autoclaved aerated concrete (AAC). In this guide, introductory information on AAC is first presented, followed by a description of its manufacture, guidance on structural design using reinforced panels, and guidance on construction with such panels. The body of this guide ends with an extensive background chapter on the material characteristics of AAC and the structural behavior and design of AAC elements.
autoclaved aerated concrete; design; sustainability; shear wall
  • babakfeyzi, subin91, PinkPant, bigone
  [CivilEA Exclusive] ACI PRC-357.3: Design and Construction of Waterfront and Coastal Concrete Marine Stru poolmand 0 784 12-06-2025, 11:09 AM
  [CivilEA Exclusive] ACI 357: Design and Construction of Fixed Offshore Concrete Structures poolmand 0 1,791 12-14-2024, 01:11 PM
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,612 01-23-2024, 12:10 PM
  ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems ir_71 5 5,589 01-17-2024, 07:34 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,923 11-26-2023, 11:51 AM
  ACI 440.7: Guide for Design & Construction of Externally Bonded FRP Systems for Stren ir_71 1 2,993 11-06-2023, 05:40 AM
  ACI 551.2: Design Guide for Tilt-Up Concrete Panels ascetic19 3 3,513 05-09-2023, 12:46 PM
