Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI MNL-7: GFRP-Reinforced Concrete Design Handbook
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
01-08-2024, 05:05 AM
ACI MNL-7 (23) GFRP-Reinforced Concrete Design Handbook
Author(s)/Editor(s): ACI/NEx | Size: 34.53 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 212 | ISBN: 9781641952309
[Image: 32860883193746467486.jpg]
The GFRP Reinforced Concrete Design Handbook is a vital reference for professionals interested in the use of non-metallic GFRP reinforcement for concrete structures. It is meant to provide valuable insight to structural engineers on understanding and utilizing the provisions of “Building Code Requirements for Structural Concrete Reinforced with Glass Fiber Reinforced Polymer (GFRP) Bars” (ACI CODE 440.11).
The GFRP Reinforced Concrete Design Handbook provides several engineering design examples for various concrete members reinforced with GFRP bars including beams, one-way slabs, two-way slabs, and slender columns. The examples help illustrate the provisions of ACI CODE 440.11 as they pertain to serviceability, flexural strength, shear strength, torsional strength, axial strength, stability, and structural analysis. Many of the examples are based on a fictious four-story GFRP reinforced concrete building to illustrate how the design provisions work together in a full building design. These examples are also closely related to the example problems presented in the ACI Reinforced Concrete Design Handbook (ACI MNL-17) to allow for comparison to the steel reinforced concrete members presented in MNL-17. Each example starts with a brief problem statement and then presents a full set of design calculations that reference the appropriate provisions in ACI CODE 440.11 (red highlighted text next to equations) to arrive at a solution. Detailed explanations of the design calculations are provided throughout.
In addition to the example problems, this handbook provides general information and guidance about the appropriate use of GFRP reinforcement, its material and durability characteristics, typical applications, and considerations for fire resistance. It also highlights key differences between designing GFRP reinforced concrete versus traditional steel reinforced concrete.
The appendix to this handbook provides additional detailed information from FRP bar manufactures on commercially available products and solutions.
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  • malc, babakfeyzi, PinkPant, cheosmith, subin91, Dell_Brett, rami1976, kowheng, xdesi, jayborre
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,267 08-17-2025, 10:25 AM
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,493 08-28-2024, 05:32 AM
  ACI 343: Analysis and Design of Reinforced Concrete Bridge Structures noelda2 3 5,009 05-12-2024, 10:46 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,734 03-04-2024, 08:35 AM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,789 03-04-2024, 07:50 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,928 11-26-2023, 11:51 AM
  PCA Simplified Design of Reinforced Concrete Buildings bigone 4 5,178 05-09-2023, 09:03 AM
