Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 201.3: TechNote: Joint Deterioration and Chloride Based Deicing Chemicals
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
10-21-2023, 12:24 PM
ACI PRC-201.3-19: TechNote: Joint Deterioration and Chloride Based Deicing Chemicals
| Size: 5.73 MB| Format: PDF| Quality: Scanner| Publisher: ACI Committee 201| pages: 6
[Image: 16188681212476918527.jpg]
Concrete pavements and exterior flatwork generally provide excellent performance in all climates and exposures. Concrete durability is an essential component in delivering the return on investment that makes concrete an economical and sustainable material. In recent years, the industry has seen an increase in premature deterioration at joints and saw cuts in concrete pavements and flatwork in areas where winter storm events demand the application of deicing chemicals, which are most commonly chloride-based.
calcium oxychloride; critical saturation; deicers; freezing-and-thawing damage; joint deterioration; supplementary cementitious materials.
  • zrilek, PinkPant, Dell_Brett, babakfeyzi, subin91, kowheng
  [CivilEA Exclusive] ACI 213.2.: Internal Curing Using Prewetted Fine Lightweight Aggregate—TechNote poolmand 0 2,748 01-05-2025, 09:05 AM
  [CivilEA Exclusive] ACI 440.10: Fire Resistance of FRP-Strengthened Concrete Members - TechNote poolmand 0 1,631 11-06-2023, 05:44 AM
  [CivilEA Exclusive] ACI 224.5: Contraction Joints in Residential Slabs-On-Ground—TechNote poolmand 0 1,598 10-25-2023, 08:04 AM
  ACI 131.3: BIM Level of Development for CIP Concrete - TechNote poolmand 0 1,561 05-02-2023, 11:18 AM
