Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D10.12M/D10.12: Guide for Welding Mild Steel Pipe
Likes: 8,311 in 1,373 posts
Given Likes: 92
09-04-2023, 11:49 AM
AWS D10.12M/D10.12-2000: Guide for Welding Mild Steel Pipe
| Size: 1.9 MB| Format: PDF| Quality: Scanner| Year: 2000| pages: 49
This guide is intended to cover such piping systems as low pressure heating, air-conditioning, refrigeration, and water supply, as well as some gas and chemical systems. These procedures include detailed welding process techniques that may be useful for teaching welders. Processes included are Shielded Metal Arc Welding (SMAW), Gas Metal Arc Welding (GMAW), Gas Tungsten Arc Welding (GTAW), Gas Shielded Flux Cored Arc Welding (FCAW-G) Flux Cored Arc Weldingβ€”Self-Shielded (FCAW-S), and Oxyfuel Welding (OFW). Qualification of these procedures to any welding standard is the responsibility of the user. This document does not address the needs of pipe steels or service conditions which may require post weld heat treatment (PWHT).
This standard makes use of both the International System of Units (SI) and U.S. Customary Units. The measurements may not be exact equivalents; therefore, each system must be used independently of the other without combining in any way. The standard with the designation D10.12:2000M uses SI Units. The standard designation D10.12M:2000 uses U.S Customary Units. The latter are shown within brackets ( ) or in appropriate columns in tables and figures. Pipe sizes are listed as DN (diameter nominal) and NPS (nominal pipe size). The exact pipe diameters are in Table C1.
  β€’ PinkPant, babakfeyzi, kowheng
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 3,014 02-03-2025, 05:56 AM
  [CivilEA Exclusive] AWS API-M: STUDY GUIDE FOR API STANDARD 1104 WELDING OF PIPELINES AND RELATED FACILIT poolmand 0 3,194 01-27-2024, 10:47 AM
  AWS J1.2M/J1.2: GUIDE TO INSTALLATION AND MAINTENANCE OF RESISTANCE WELDING MACHINES poolmand 0 2,940 01-22-2024, 12:08 PM
  AWS G2.5/G2.5M: GUIDE FOR THE FUSION WELDING OF ZIRCONIUM AND ZIRCONIUM ALLOYS poolmand 0 3,157 01-22-2024, 12:03 PM
  AWS G2.4/G2.4M: GUIDE FOR THE FUSION WELDING OF TITANIUM AND TITANIUM ALLOYS poolmand 0 3,010 01-22-2024, 11:58 AM
  AWS F1.6: GUIDE FOR ESTIMATING WELDING EMISSIONS FOR EPA AND VENTILATION PERMIT REPOR poolmand 0 1,621 01-22-2024, 10:37 AM
  AWS F1.3M: A SAMPLING STRATEGY GUIDE FOR EVALUATING CONTAMINANTS IN THE WELDING ENVIR poolmand 0 1,538 01-22-2024, 10:32 AM
