Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D10.11M/D10.11: Guide for Root Pass Welding of Pipe Without Backing
Threads: 757
Likes: 8,270 in 1,355 posts
Given Likes: 88
09-04-2023, 11:46 AM
AWS D10.11M/D10.11-2007: Guide for Root Pass Welding of Pipe Without Backing
| Size: 591 KB| Format: PDF| Year: 2007 Edition, 2007| pages: 36
This document describes how to make root weld passes on circumferential pipe groove welds using open root joints with filler metal additions, tightly-fitted joints without the addition of filler metal, and joints with consumable inserts. Joint designs, fitting techniques, consumable insert configurations, filler and base metal combinations, purging, and welding processes are discussed. This publication does not address joints made using backing rings and techniques applicable to mechanized orbital welding.
Safety and health issues and concerns are beyond the scope of this standard, and therefore are not fully addressed herein. Safety and health information is available from other sources, including, but not limited to, ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes, and applicable federal and state regulations. See Clauses 2 and 15 and Annex A for additional safety and health references.
Introduction.
When the pipe system designer has determined that the use of backing rings is unacceptable due to service conditions and that complete joint penetration, including a continuous root side surface, is needed, butt joints may be made from one side using the groove designs and techniques described in this document. Although gas tungsten arc welding (GTAW) is most commonly used for precise control in root pass welding, shielded metal arc welding (SMAW) and gas metal arc welding (GMAW) are also widely used.
Units of Measure.
This standard makes use of both the International System of Units (SI) and U.S. Customary Units. The latter are shown within brackets [ ] or in appropriate columns in tables and figures. The measurements may not be exact equivalents; therefore, each system must be used independently.
To identify nominal pipe sizes in both SI and U.S. Customary Units, the following designations are used:
1. DN (Diameter Nominal) is the SI designation.
2. NPS (Nominal Pipe Size) is the U.S. Customary designation.
  • PinkPant, babakfeyzi, kowheng
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 2,892 02-03-2025, 05:56 AM
  [CivilEA Exclusive] AWS API-M: STUDY GUIDE FOR API STANDARD 1104 WELDING OF PIPELINES AND RELATED FACILIT poolmand 0 3,074 01-27-2024, 10:47 AM
  AWS J1.2M/J1.2: GUIDE TO INSTALLATION AND MAINTENANCE OF RESISTANCE WELDING MACHINES poolmand 0 2,811 01-22-2024, 12:08 PM
  AWS G2.5/G2.5M: GUIDE FOR THE FUSION WELDING OF ZIRCONIUM AND ZIRCONIUM ALLOYS poolmand 0 3,023 01-22-2024, 12:03 PM
  AWS G2.4/G2.4M: GUIDE FOR THE FUSION WELDING OF TITANIUM AND TITANIUM ALLOYS poolmand 0 2,876 01-22-2024, 11:58 AM
  AWS F1.6: GUIDE FOR ESTIMATING WELDING EMISSIONS FOR EPA AND VENTILATION PERMIT REPOR poolmand 0 1,567 01-22-2024, 10:37 AM
  AWS F1.3M: A SAMPLING STRATEGY GUIDE FOR EVALUATING CONTAMINANTS IN THE WELDING ENVIR poolmand 0 1,476 01-22-2024, 10:32 AM
