Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C2.20/C2.20M: Specificatiopn for Thermal Spraying Zinc Anodes on Steel Reinforced
Threads: 757
Likes: 8,270 in 1,355 posts
Given Likes: 88
08-27-2023, 06:28 AM
AWS C2.20/C2.20M-2016: Specificatiopn for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete
| Size: 6.66 MB| Format: PDF| Quality: Scanner| Publisher: American Welding Society, Inc. (AWS) | Year: 2nd Edition, 2016| pages: 48
[Image: 62824424408025010523.png]
AWS C2.20/C2.20M, 2nd Edition, 2016 - Specificatiopn for Thermal Spraying Zinc Anodes on Steel Reinforced Concrete
This standard covers the application of zinc thermal spray coatings to steel reinforced concrete using arc and flame spray equipment. The application of the zinc on steel reinforced concrete requires an electrical connection to the steel reinforcement. Although other metals can also be applied with these methods and equipment, at this time the standard only covers zinc and zinc alloys. This standard is formatted as an industrial process instruction: job description, safety, Pass/Fail Job Reference Standard, feedstock materials, equipment, a step-by-step process instruction for surface preparation, thermal spraying, quality control (QC), and a Job Control Record.
This standard is based on the literature, equipment, process developments, and industrial practices known at the time of publication. This standard does not cover the design standards or recommended practices for cathodic protection (CP) systems. The design of a CP system for reinforced concrete structures, including the connection of the zinc coating to the steel reinforcement, should be undertaken by an experienced and qualified Corrosion Engineer. Table 1 summarizes inspection, test methods, and acceptance criteria that shall be employed.
  • babakfeyzi, kowheng, PinkPant
  AWS C4.6M: Thermal Cutting Classification of Thermal Cuts Geometric Product Specifica poolmand 0 1,480 08-30-2023, 08:30 AM
  AWS C2.18: Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminu poolmand 0 1,461 08-26-2023, 12:33 PM
