Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 421.3: Guide to Design of Reinforced Two-Way Slab Systems
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
05-08-2023, 01:32 PM
ACI PRC-421.3-15 Guide to Design of Reinforced Two-Way Slab Systems
Author(s)/Editor(s): ACI Committee 421 - (Joint ACI-ASCE) | Size: 2.61 MB| Format: PDF| Quality: Original preprint| Year: 2015| pages: 28 | ISBN: 9781942727569
[Image: 46522473217144237403.png]
This guide presents analysis methods, design procedures, slab reinforcement and detailing practices, and strength and serviceability considerations, as well as information for the resistance to lateral forces for slab-column frames. It also covers the design for flexure and shear and torsion, as well as the effect of openings. Both two-way nonprestressed slabs and post-tensioned slabs are included.
Keywords: analysis method; deflection; direct design; flat plates; flat slabs; post-tension; reinforcement; shear; shearhead; slab-column frame; two-way slabs.
  • babakfeyzi, milova, PinkPant, malc, Dell_Brett
  ACI SP-146: Thin Reinforced Concrete Products and Systems poolmand 0 1,565 03-04-2024, 08:14 AM
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,613 01-23-2024, 12:10 PM
  ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems ir_71 5 5,596 01-17-2024, 07:34 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,929 11-26-2023, 11:51 AM
  ACI 440.7: Guide for Design & Construction of Externally Bonded FRP Systems for Stren ir_71 1 2,996 11-06-2023, 05:40 AM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,776 05-08-2023, 01:39 PM
  ACI 314: Guide to Simplified Design for Reinforced Concrete Buildings hamex 3 4,124 05-03-2023, 08:27 AM
