Civil Engineering Association eBooks Structural Books Analysis & Design Design of Hybrid Structures: Where Steel Profiles Meet Concrete
 carolinandra
Colombia
User ID: 12281
Threads: 110
Likes: 2,885 in 157 posts
Given Likes: 1333
04-07-2023, 02:54 PM
Author(s)/Editor(s): AndrΓ© Plumier | Size: 37.9 MB| Format: PDF| Quality: Original preprint| Publisher: CRC Press| Year: 23| pages: 350 | ISBN: 0367712075,9780367712075
[Image: 66637054886939145979.png]
Well-designed hybrid structures can combine the different performance strengths materials. This guide focuses on design approaches for concrete structures reinforced in an unconventional way by steel profiles. It explains force transfer mechanisms of steel profiles and oncrete interfaces, and an analysis of the characteristics of hybrid structures, including slendercomponents. Several types of hybrid designs are addressed: walls and columns with several embedded steel profiles, connections strengthened by steel profiles between steel and composite or reinforced concrete components, including the specific case of shear keys connecting deep beams or flat slabs to columns. The transition zones in partly reinforced concrete and partly composite columns are also covered.
Design of Hybrid Structures draws on the European SMARTCOCO research project of experimentation and numerical modelling, giving practical guidance for designers and introducing the subject for researchers and graduate students.
[-] The following 18 users Like carolinandra's post:18 users Like carolinandra's post
  β€’ subin91, jcbv, Dell_Brett, zrilek, blaze, cheosmith, babakfeyzi, cace-01, PinkPant, simanta, lasalleguy, rendel_Β©, Umer.Aleem, lisine, sodapas, rigid_joint, kowheng, miquan
  Composite Structures of Steel and Concrete: Beams, Slabs, Columns, Frames Flexi 19 33,823 01-26-2022, 04:45 AM
Last Post: Veggeta
  Tall building design: steel, concrete, and composite systems asim99 3 9,175 12-23-2021, 01:10 PM
Last Post: babakfeyzi
  Principles of Structural Design: Wood, Steel, and Concrete, Second Edition cace-01 4 11,914 11-24-2019, 01:32 PM
Last Post: carolinandra
  Plastic Methods for Steel and Concrete Structures amindoxiti 3 9,992 02-12-2019, 06:18 PM
  Performance based plastic design of earthquake resistant steel structures sabooryan 1 5,841 09-14-2017, 08:53 AM
  Design of Steel-to-Concrete Joints Design Manual I rami1976 4 7,390 01-18-2016, 12:47 AM
Last Post: concreteok
  Advanced Analysis and Design for Fire Safety of Steel Structures ir_71 2 6,972 07-10-2014, 06:03 PM
Last Post: Mohammad6299
