Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] ASTM D1195 / D1195M - 09(2015) & ASTM D1196 / D1196M - 12(2016)
[Request] ASTM D1195 / D1195M - 09(2015) & ASTM D1196 / D1196M - 12(2016)
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
02-18-2021, 09:02 AM (This post was last modified: 02-19-2021, 10:23 AM by Dell_Brett. Edit Reason: ADD REQUEST PREFIX )
  • Article/eBook Full Name:
  • ASTM D1195 / D1195M - 09(2015) & ASTM D1196 / D1196M - 12(2016)
  • Author(s):
  • ASTM
  • Related Links:
  • Code:
ASTM D1195 / D1195M - 09(2015) : Standard Test Method for Repetitive Static Plate Load Tests of Soils and Flexible Pavement Components, for Use in Evaluation and Design of Airport and Highway Pavements
ASTM D1196 / D1196M - 12(2016) : Standard Test Method for Nonrepetitive Static Plate Load Tests of Soils and Flexible Pavement Components, for Use in Evaluation and Design of Airport and Highway Pavements
[*]This post has been made by CivilEA Post-Generator V2.3.1
[-] The following 1 user Likes PinkPant's post:1 user Likes PinkPant's post
  â€¢ freequo
  [REQUEST] ASTM C635/C635M-22 Badis 1 521 06-17-2026, 06:06 AM
  [REQUEST] ASTM D516 -22 : Standard Test Method for Sulfate Ion in Water utan 1 1,906 11-12-2023, 08:07 AM
  [REQUEST] ASTM D6927 -22 : Standard Test Method for Marshall Stability and Flow of Asphalt Mixt utan 1 1,707 11-04-2023, 11:01 AM
  [REQUEST] ASTM ASTM D4829-21 : Standard Test Method for Expansion Index of Soils utan 1 1,733 11-01-2023, 07:19 AM
  [REQUEST] ASTM D4186/D4186M-20e1 - Standard Test Method for One-Dimensional Consolidation Prope utan 1 1,811 10-24-2023, 11:10 AM
  [REQUEST] ASTM REBAR STANDARDS aslam 0 1,482 10-01-2022, 02:17 PM
Last Post: aslam
  [REQUEST] ASTM A1044 / A1044M - 16ae1 Standard specification for steel stud assemblies aslam 1 1,848 09-17-2021, 05:59 PM
Last Post: KMABD
