Civil Engineering Association eBooks Structural Books Steel Design guide for concrete-filled double skin steel tubular structures
 carolinandra
Colombia
User ID: 12281
Threads: 110
Likes: 2,885 in 157 posts
Given Likes: 1333
04-16-2019, 04:02 PM
Author(s)/Editor(s): Lin-Hai Han, Dennis Lam, David A. Nethercot | Size: 8.39 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2019 | pages: 127 | ISBN: ISBN-13: 978-1138340237 ISBN-10: 1138340235
[Image: 89477394279583932730.jpg]
This is the first design guide on concrete filled double skin steel tubular (CFDST) structures. It addresses in particular CFDST structures with plain concrete sandwiched between circular hollow sections, and provides the relevant calculation methods and construction provisions for CFDST structures.
These inherit the advantages of conventional concrete-filled steel tubular (CFST) structures, including high strength, good ductility and durability, high fire resistance and favourable constructability. Moreover, because of their unique sectional configuration, CFDST structures have been proved to possess lighter weight, higher bending stiffness and better cyclic performance than conventional CFST. Consequently CFDST can offer reduced concrete consumption and construction costs.
This design guide is for engineers designing electrical grid infrastructures, wind power towers, bridge piers and other structures requiring light self-weight, high bending stiffness and high bearing capacity.
[-] The following 31 users Like carolinandra's post:31 users Like carolinandra's post
  â€¢ temp1366, aslam, RajaK, subin91, sabooryan, zrilek, Nita1391, rami1976, cheosmith, PinkPant, febo927, amindoxiti, gulilero, malc, Dell_Brett, kowheng, oanm2000, mgdario, hatkam, vvvv, blaze, Andrew seah, pedzaquino, civilfafa, Hengki, dizz, cristi, hodzicemir, cace-01, levanduy, simanta
  Cold-Formed Tubular Members and Connections. Structural Behaviour and Design TAFATNEB 0 3,276 04-25-2023, 10:48 AM
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 4,769 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 8,148 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 3,315 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 2,023 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 2,667 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 4,022 12-17-2019, 06:53 AM
