Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Effective Stress and Equilibrium Equation for Soil Mechanics
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
02-04-2018, 07:09 PM
Author(s)/Editor(s): Longtan Shao, Xiaoxia Guo, Shiyi Liu, Guofeng Zheng | Size: 10 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2017 | pages: 160 | ISBN: 1138092312, 9781138092310, 9781315107554, 1315107554, 9781351607421, 1351607421
[Image: 65945875902817398396.jpg]
The concept of effective stress and the effective stress equation is fundamental for establishing the theory of strength and the relationship of stress and strain in soil mechanics and poromechanics. However, up till now, the physical meaning of effective stress has not been explained clearly, and the theoretical basis of the effective stress equation has not been proposed. Researchers have not yet reached a common understanding of the feasibility of the concept of effective stress and effective stress equation for unsaturated soils.
Effective Stress and Equilibrium Equation for Soil Mechanics discusses the definition of the soil skeleton at first and clarifies that the soil skeleton should include a fraction of pore water. When a free body of soil skeleton is taken to conduct internal force analysis, the stress on the surface of the free body has two parts: one is induced by pore fluid pressure that only includes normal stress; the other is produced by all the other external forces excluding pore fluid pressure. If the effective stress is defined as the soil skeleton stress due to all the external forces excluding pore fluid pressure, the effective stress equation can be easily obtained by the internal force equilibrium analysis. This equation reflects the relationship between the effective stress, total stress and pore fluid pressure, which does not change with the soil property. The effective stress equation of saturated soils and unsaturated soils is unified, i.e., o˜=o˜t –Seuw–(1–Se)ua. For multiphase porous medium, o˜=o˜t –u*,u*=Seiui(i=1,2,...,M). In this book, a theoretical formula of the coefficient of permeability for unsaturated soils is derived. The formula of the seepage force is modified based on the equilibrium differential equation of the pore water. The relationship between the effective stress and the shear strength and deformation of unsaturated soils is preliminarily verified. Finally, some possibly controversial problems are discussed to provide a better understanding of the role of the equilibrium equation and the concept of effective stress.
Thanks to Original Uploader
[-] The following 14 users Like cace-01's post:14 users Like cace-01's post
  • amindoxiti, cheosmith, gulilero, oanm2000, zrilek, PinkPant, isurya, febo927, OSHO, ELAHI1979, Dell_Brett, Trishu999, rizal13, levanduy
  Introduction to Soil Mechanics febo927 2 4,120 05-18-2022, 05:33 AM
  Soil Settlement and the Concept of Effective Stress and Shear Strength Interaction poolmand 0 3,172 08-02-2021, 07:44 AM
  Handbook of Soil Mechanics - Earthworks, Foundations and Highway Engineering cace-01 1 4,549 08-30-2020, 01:36 PM
Last Post: babakfeyzi
  Soil Mechanics in Engineering Practice Flexi 8 9,041 09-21-2019, 01:00 AM
  Soil Mechanics Through Project-Based Learning[/size OSHO 1 3,502 06-23-2019, 02:49 PM
Last Post: ska51
  Unsaturated Soil Mechanics in Engineering Practice asim99 3 4,782 10-12-2018, 03:10 PM
Last Post: febo927
  Fundamentals of Soil Mechanics-1948 febo927 0 3,056 09-21-2018, 12:12 PM
Last Post: febo927
