Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Paper : Fracture Energy of High-Strength Concrete
[Request] Paper : Fracture Energy of High-Strength Concrete
 eyad
User ID: 29815
Threads: 8
Likes: 3 in 2 posts
Given Likes: 9
02-22-2017, 05:17 AM
Can i please get this paper from ACI journal
Title: Fracture Energy of High-Strength Concrete
Author(s): David Darwin, Shawn Barham, Rozalija Kozul, and Shuguang Luan
Publication: Materials Journal
Volume: 98
Issue: 5
Appears on pages(s): 410-417
Keywords: aggregates; compressive strength; flexural strength; fracture mechanics; high-strength concrete; water-cementitious materials ratio
Date: 9/1/2001
Abstract:
The effects of water-cementitious materials ratio, age, and aggregate type on the compressive strength, flexural strength, and fracture energy of concretes with compressive strengths ranging from 20 to 99 MPa (2900 to 14,400 psi) are studied. Concrete mixtures contain either basalt or crushed limestone aggregate with maximum sizes of 12 or 19 mm (1/2 or 3/4 in.). Mixtures are tested at ages ranging from 5 to 180 days and have water-cementitious (w/cm) ratios ranging from 0.24 to 0.50. High-strength concrete containing the higher-strength, basalt coarse aggregate attains higher compressive and flexural strengths than high-strength concrete containing limestone. The compressive and flexural strengths of medium and normal-strength concretes (fcยข up to approximately 60 MPa [9000 psi]) are affected little by aggregate type. Concrete containing basalt yields significantly higher fracture energy than concrete containing limestone, with fracture energy governed principally by aggregate properties, independent of compressive strength, w/cm ratio, and age. Overall, as compressive strength increases, the energy stored in the material at the peak tensile load increases while the ability of the material to dissipate energy remains approximately constant. The result is increasingly brittle behavior as compressive strength increases.
Thanks
  โ€ข
 xnr09
User ID: 9060
Threads: 21
Likes: 1,120 in 126 posts
Given Likes: 74
02-22-2017, 08:14 AM (This post was last modified: 02-23-2017, 12:32 AM by faros3000. Edit Reason: Document links were originally posted here. The post was updated with the URL of the correct post. )
Hi
You can find this one in the author's ResearchGate page.
Find it in the following thread:
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
Cheers
xnr09
[-] The following 6 users Like xnr09's post:6 users Like xnr09's post
  โ€ข eyad, blaze, Dell_Brett, ska51, malc, zrilek
  [REQUEST] ACI paper - Concrete Capacity Design (CCD) Approach for Fastening to Concrete Agent66 1 1,918 08-11-2020, 09:12 AM
Last Post: AlmostThere
  [REQUEST] Shearing Strength of Reinforced Concrete Slabs lisine 0 1,610 04-08-2019, 02:35 PM
  [REQUEST] ACI paper : Early-Age Strength Development of Concrete Incorporating Fly Ash and Cond eyad 1 2,062 02-26-2017, 12:01 PM
Last Post: xnr09
