Civil Engineering Association Software Software Product Autodesk Products AutoCAD Structure Detailing 2010 Multilingual SP2 Full
 timosi™
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
10-26-2009, 11:08 AM (This post was last modified: 11-04-2009, 11:40 AM by timosi™.)
Don't support for windows7
[Image: 24tjzs2wy1xojovk5sf.png]
AutoCAD® Structural Detailing software, built on the familiar AutoCAD® platform, enhances productivity with precise detailing and creation of fabrication shop drawings for steel and concrete structures. AutoCAD Structural Detailing includes two powerful toolsets for structural steel and concrete reinforcement detailing projects. AutoCAD Structural Detailing is part of AutoCAD® Revit® Structure Suite.
AutoCAD® Structural Detailing software enables you to quickly and efficiently generate detailing and creation of fabrication shop drawings for reinforced concrete and steel structures. AutoCAD® Structural Detailing: Intelligent Structural Objects
In AutoCAD Structural Detailing, engineers and drafters can create structural steel models or rebar drawings using intelligent objects such as beams, plates, columns, walls, and reinforcement bars, rather than lines and curves. You can virtually cut, lengthen, bend, split, and merge objects. They dynamically react to changes and automatically update material takeoffs.
AutoCAD® Structural Detailing: Powerful Macros
Powerful Macros
AutoCAD Structural Detailing provides special tools and smart macros that enable fast automation of time-consuming structural tasks. Use macros to generate typical parts of steel structures (including connections, roof trusses, stairs, railings, and ladders), automatically place elements (such as grates or purlins), or generate complete concrete reinforcement drawings of typical parts of structures, together with rebar descriptions and material takeoffs.
screenshots:
[Image: 38kxufp1hh363n906b9y.png]
Download Links:
or
Product Key:
keygen X-force
Hot fix 4:
Password:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 60 users Like timosi™'s post:60 users Like timosi™'s post
  • struceng, struceng, oanm2000, oanm2000, dfense, dfense, yucapareja, yucapareja, Dell_Brett, Dell_Brett, cardinal85, cardinal85, Ultra Zone, Ultra Zone, abudabeeja, abudabeeja, rohailiyaz, rohailiyaz, Tensor, Tensor, henrycv, henrycv, cristi, cristi, zrilek, zrilek, blackjack, blackjack, lax11, cgedmundo, yacinesoft, vinnunsam, engr1900, ruaumoko, jferrer, mkbiksi, KAMM, ChisTeam, Nilupa, spazkyjon, blabop33, erimajus, relu59, pulikesi23rd, selm27, hsccindia, leonelmariana, julioreptil, StaadEng, uomo_ragno, Vicoq, belgacem, sc1201, Panjack39, kamran, Quantumm, ambrish, ramla2002, eng amin, sructme
 timosi™
User ID: 3890
Threads: 138
Given Likes: 1812
10-28-2009, 07:39 AM
(10-28-2009, 06:18 AM)rohailiyaz Wrote: i am using mediafire to dload bt i cant dload 11 par..dnt knw whts the reason. could sum1 kindly upload it seperatly?
dear rohailiyaz
Use IE 8.0 instead of Fire Fox to download part11 or download with new links:
regard
1.Follows the rules
4.Do not spam
[-] The following 3 users Like timosi™'s post:3 users Like timosi™'s post
  • rohailiyaz, rohailiyaz, Nilupa
 timosi™
User ID: 3890
Threads: 138
Given Likes: 1812
10-28-2009, 03:34 PM
About SP1:
About SP2:
About Hot Fix1:
About Hot Fix2:
About Hot Fix3:
It will expain all
regard
timosi
1.Follows the rules
4.Do not spam
[-] The following 11 users Like timosi™'s post:11 users Like timosi™'s post
  • niki102, niki102, Ultra Zone, Ultra Zone, yucapareja, yucapareja, Dell_Brett, Dell_Brett, mkbiksi, sssmou, ruwan75
 fiaz
User ID: 7442
Threads: 2
Likes: 13 in 6 posts
Given Likes: 9
11-29-2009, 03:56 PM (This post was last modified: 06-06-2012, 07:53 AM by Dell_Brett.)
Dear Imran,
Thank you for your reply.I have successfully un zip the files but with lot of errors.My installation was stopped after 25% of installation.
I have just successfully installed AutoCad Revit Structure Suite 2010 from the others links given below.I am using 32 Bits Window Vista. You have to use KeyGen posted by Mr.Timosi to crack the same.You can download one link at a time in half an hour interval but downloading speed is good.
Thanks.
Fiaz
[-] The following 1 user Likes fiaz's post:1 user Likes fiaz's post
  • u4406014
  Autodesk AutoCAD Structural Detailing 2014 (x86/x64) AIO BennyP 4 13,352 04-11-2015, 10:30 AM
Last Post: alnasir
  Autodesk AutoCAD Structural Detailing 2015 64bit BennyP 1 12,045 03-16-2015, 08:45 AM
Last Post: gianniorlati
  Portable Autocad 2010 Lite kirankumarklk 2 8,635 04-02-2013, 07:05 AM
  Autodesk AutoCAD Structural Detailing 2013 (x86/x64) BennyP 10 23,513 11-27-2012, 09:41 AM
Last Post: devilmaycry
  AutoCAD Structural Detailing 2013 (x32/x64) Trial BennyP 0 5,560 04-01-2012, 03:16 PM
  Autodesk AutoCAD Structural Detailing 2012 x32 x64 BennyP 18 32,644 03-01-2012, 02:19 PM
  AutoCAD Structural Detailing 2010 dancob 4 17,709 01-10-2012, 02:46 PM
Last Post: gargi
