Civil Engineering Association Software Software Product Autodesk Products Autodesk 3ds Max 2017
 rami1976
User ID: 34597
Threads: 341
Likes: 9,524 in 1,138 posts
Given Likes: 1388
04-20-2016, 07:28 AM (This post was last modified: 04-20-2016, 07:30 AM by rami1976.)
[Image: 27060634287173726356.jpg]
3ds Max software provides a comprehensive 3D modeling, animation, rendering, and compositing solution for games, film, and motion graphics artists. 3ds Max has tools for crowd generation, particle animation, and perspective matching, as well as support for DirectX 11 shaders.
Here are some of the Autodesk 3ds Max 2017 changes are:
– Viewport navigation: Orbit point of interest / Orbit sub object
– Viewport zoom is now infinite
– Local Aligned coordinate system for sub objects. Verts and edges have local coordinate systems.
– mirror tool now has geometry mode – adds geometry modifier
– UV editor; flatten by material id
– UV editor; flatten by smoothing groups
– A lot of new tools in curve editor + buffer curves
– Offset controllers
– Camera sequencer
– Physical material
– Slate material editor can now pick mats from legacy editor sample slots via RMB
– New render added – ART. Seems like it’s the same ray tracing engine used in 360, but with animation ability.
– Mental ray is now installed separately (as a sub-component).
– Scene converter – converts scenes to ART rendered.
  • learner20, oanm2000, Dell_Brett, temp1366, golpesar
 temp1366
Senior Member
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 741
04-30-2016, 03:36 PM
AutoDesk 3ds Max 2017 Sample Files
[-] The following 4 users Like temp1366's post:4 users Like temp1366's post
  • rami1976, Dell_Brett, oanm2000, golpesar
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1388
04-30-2016, 04:18 PM
Autodesk 3ds Max 2017 - torrent link
  • temp1366, Dell_Brett, oanm2000, roger17, PinkPant, vinnunsam
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1388
10-04-2016, 06:28 AM
Autodesk 3ds Max 2017 Service Pack 3
The following list contains issues fixed in this release (Service Pack 3 contains all previous Service Pack fixes for 3ds Max 2017):
Curve Editor values shown in comma, typing in with points
TMCache - exporting CAT animation produces flipped animation and 3ds Max lockup
Customer Error Repor with Cloth
OGS Security Update
Components Integration
FileIO Security Update
Components IntegrationMerge OBJ import / export change to 2017
OBJ Export/Import Presets settings dialog is not DPI aware and has cutoff buttons
X-Ref objects are scattered randomly in 3ds Max 2017
OBJ importer corrupts geometry
OBJ Import with Multi/Sub Object Material is not complete
OBJ exporter breaks uvs when there are specified normals .   etc..
see more at :
[-] The following 7 users Like rami1976's post:7 users Like rami1976's post
  • PinkPant, promo8, oanm2000, Dell_Brett, bridgeengineer, vinnunsam, golpesar
  Autodesk Structural Bridge Design 2017 TAFATNEB 3 9,725 03-31-2017, 10:00 AM
  Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 5,056 03-03-2017, 11:05 AM
Last Post: bus001
  AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 6,395 03-01-2017, 01:35 PM
  Autodesk Revit 2017.1.1 TAFATNEB 0 5,205 12-19-2016, 07:26 AM
  Autodesk AutoCAD 2017.1.1 TAFATNEB 1 7,069 12-18-2016, 04:58 AM
  Autodesk 2017 keys BennyP 2 7,746 11-26-2016, 02:14 PM
Last Post: camto2
  Autodesk REVIT 2017 (x64) BennyP 8 14,976 11-25-2016, 06:42 PM
Last Post: tudao
