Civil Engineering Association eBooks Structural Books Analysis & Design Structural Design: A Practical Guide for Architects, 2nd Edition
 ibg0203
China
User ID: 1557
Threads: 288
Likes: 6,208 in 686 posts
Given Likes: 1411
04-10-2016, 05:19 PM
Author(s)/Editor(s): James R. Underwood, Michele Chiuini | Size: 479 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 2007 | pages: 816 | ISBN: 0471789046
[Image: 74959209652165525143.jpg]
Written for the practicing architect, Structural Design addresses the process on both a conceptual and a mathematical level. Most importantly, it helps architects work with structural consultants and understand all the necessary considerations when designing structural systems. Using a minimum of simple math, this book shows you how to make correct design calculations for structures made from steel, wood, concrete, and masonry. What?s more, this edition has been completely updated to reflect the latest design methods and codes, including LRFD for steel design. The book was also re–designed for easy navigation. Essential principles, as well as structural solutions, are visually reinforced with hundreds of drawings, photographs, and other illustrations––making this book truly architect–friendly.
[-] The following 25 users Like ibg0203's post:25 users Like ibg0203's post
  • cace-01, gulilero, Jackass, bridgeengineer, concreteok, psk62, Andrew seah, Trishu999, chottabhai, PinkPant, hatkam, milova, f_slikken, oanm2000, carolinandra, Dell_Brett, mgdario, slowet, knrsa, monter, chairatpk, ruaumoko, simanta, harsono, Hengki
  Practical guide to structural robustness and disproportionate collapse in building muhammad999 5 10,255 10-30-2020, 12:27 PM
Last Post: vampirucho
  Principles of Structural Design: Wood, Steel, and Concrete, Second Edition cace-01 4 11,890 11-24-2019, 01:32 PM
Last Post: carolinandra
  Above Ground Storage Tanks: Practical Guide to Construction, Inspection, and Testing cace-01 1 5,544 06-14-2018, 12:27 PM
Last Post: febo927
  Structure As Architecture: A Source Book for Architects and Structural Engineers, 2Ed asim99 4 10,644 08-03-2017, 10:25 AM
  Structural Elements for Architects and Builders ibg0203 5 11,419 01-08-2017, 11:20 PM
Last Post: concreteok
  Structural Scheme Design Guide Version 3.0 gboyega 2 9,405 05-16-2016, 10:14 AM
Last Post: RyanRS
  Structural Competency for Architects ibg0203 2 6,104 02-20-2016, 05:18 PM
Last Post: ibg0203
