Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] ASTM A1067M-12a-Standard Specification for Test Coupons for Steel Castings
[Request] ASTM A1067M-12a-Standard Specification for Test Coupons for Steel Castings
Likes: 12,075 in 1,233 posts
12-05-2015, 08:12 AM
  • Article/eBook Full Name: ASTM A1067M-12a-Standard Specification for Test Coupons for Steel Castings
  • Author(s): Subcommittee: A01.18
  • Publish Date: 2012
  • Published By: ASTM
  • Related Links:
Threads: 1,298
12-06-2015, 06:15 AM
ASTM A1067 / A1067M - 12a Standard Specification for Test Coupons for Steel Castings
[Image: 11619448684013284368.jpg]
  • Published By: ASTM International
  • Published Year: 2012
  • Size: 0.3 MB
  • Quality: Original preprint
  • Abstract: This specification defines the geometries of several
    separately-cast and integrally-cast test coupons for use as
    specified in the applicable casting product or common requirements
    standard. This standard does not address procedures for
    molding, casting, heat treating, machining, or testing; these
    items are addressed as needed and appropriate by the applicable product or common requirements standard.
  • f_slikken, pezhmankhan, oanm2000, Dell_Brett, PinkPant
  [REQUEST] ASTM D516 -22 : Standard Test Method for Sulfate Ion in Water utan 1 1,796 11-12-2023, 08:07 AM
  [REQUEST] ASTM D6927 -22 : Standard Test Method for Marshall Stability and Flow of Asphalt Mixt utan 1 1,599 11-04-2023, 11:01 AM
  [REQUEST] ASTM ASTM D4829-21 : Standard Test Method for Expansion Index of Soils utan 1 1,633 11-01-2023, 07:19 AM
  [REQUEST] ASTM D4186/D4186M-20e1 - Standard Test Method for One-Dimensional Consolidation Prope utan 1 1,713 10-24-2023, 11:10 AM
  [REQUEST] ASTM A1044 / A1044M - 16ae1 Standard specification for steel stud assemblies aslam 1 1,753 09-17-2021, 05:59 PM
Last Post: KMABD
  [REQUEST] ASTM D1195 / D1195M - 09(2015) & ASTM D1196 / D1196M - 12(2016) PinkPant 0 1,601 02-18-2021, 09:02 AM
Last Post: PinkPant
  [REQUEST] ASTM D6760 - 16 Standard Test Method for Integrity Testing of Concrete Deep PinkPant 3 2,623 07-15-2020, 10:04 AM
Last Post: CAMSECT
