Civil Engineering Association eBooks Journals, Papers and Presentations Paper: Ductile Concentrically Braced Frames Using Slotted Bolted Joints
 struceng
Russian Federation
User ID: 258
Threads: 259
Likes: 10,197 in 602 posts
Given Likes: 741
10-24-2009, 09:41 AM (This post was last modified: 10-24-2009, 09:43 AM by struceng.)
Paper:
[Image: d4l17rn1y4lw68fgwak.gif]
Info:
Butterworth, J., Ductile Concentrically Braced Frames Using Slotted Bolted Joints, SESOC Journal, Vol. 13, No. 1, 2000.
Summary
The use of passive energy dissipating devices to protect structures from seismic damage is starting to receive more attention. This paper explores the use of such a device, the slotted bolted joint, as a means of providing concentrically braced frames (CBFs) with similar levels of ductility to moment-resisting frames whilst avoiding the associated plastic hinge damage. The benefits of this approach include the ability to consider CBFs as potential candidates for stiff, lightweight seismic-resisting systems, with the promise of lower repair costs after a damaging seismic event. In this preliminary study, sample joints are described and some results based on time-history analyses of a trial 6 storey structure subjected to a range of ‘inelastic demandlevel’ earthquake records presented. Structure ductility factors ranging from 6.7 to 18.6 were observed with maximum drift levels well within code limits.
Does anyone have "Behaviour of steel structures in seismic areas, STESSA 2003 by Federico M. Mazzolani" ebook? I need the paper "Experimental and analytical evaluation of chevron braces with slotted brace-to-beam connections" from this book. Thanks to the uploader by now.
Download Links:
Generated by CivilEA PostGen v1.3
[-] The following 12 users Like struceng's post:12 users Like struceng's post
  • timosi™, timosi™, Ultra Zone, Ultra Zone, Dell_Brett, Dell_Brett, YeiYei, YeiYei, levanduy, zrilek, Grunf, bigone
  Uncertainties and dynamic problems of bolted joints and other fasteners TAFATNEB 0 4,405 12-20-2013, 12:05 PM
  Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 5,103 11-28-2013, 12:08 PM
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 5,986 11-28-2013, 11:58 AM
  Seismic Braced Frames preceptor 4 9,063 08-14-2013, 10:21 PM
Last Post: ssobhan
  On the Design of Eccentrically Braced Frames shadabg 0 3,992 07-23-2012, 07:03 AM
Last Post: shadabg
  SCI P249: Design of kidney shaped slotted connections ir_71 0 3,614 04-12-2011, 04:21 AM
  Ductile design Approach for R/C Frames - R. Park aflv 0 5,017 10-24-2009, 10:26 PM
Last Post: aflv
