Civil Engineering Association eBooks Journals, Papers and Presentations Cement and Concrete Composites journal
Away  bridgeengineer
Poland
User ID: 93214
Threads: 49
Likes: 1,023 in 110 posts
Given Likes: 4769
02-02-2015, 06:03 PM (This post was last modified: 02-02-2015, 06:15 PM by bridgeengineer.)
Size: 29 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 1995
[Image: 75681396020606136123.gif]
This journal is designed to reflect current developments and advances being made in the general field of cement-concrete composites technology and in the production, use, and performance of cement-based construction materials. The word cement is interpreted in a wide sense, including not only Portland cement but also blended cements and other binding materials. In addition to novel aspects of conventional concrete materials, the journal covers a wide range of composite materials such as fiber-reinforced cement composites, polymer cement composites, polymer impregnated composites, ferrocement, and cement composites containing special aggregate inclusions or waste materials. Original papers dealing with microstructure (as it relates to engineering properties), material properties, testing and test methods, fracture mechanics, durability aspects, composite mechanics/technology, modelling, design, fabrication and practical applications of these materials form the major themes of the journal. Provided there is sufficient linkage to properties defined at the material scale, papers concerning the behavior of structural components and systems, in situ performance, and field studies will also be accepted for review, as well as those concerning the repair and maintenance, serviceability behavior, and sustainability of structures made with these materials.
The journal has within the above context several specific objectives. It wants to foster a better understanding of construction materials, provide a forum for unusual and unconventional materials, encourage the development of low cost energy saving materials and bridge the gap between materials science, engineering performance, environmental effects, in situ behavior, design/service life and construction. It is the intention of the journal to also publish special issues devoted to topics of current or emerging interest. The journal aims to provide a unifying basis for collaboration between materials scientists, engineers, designers and fabricators.
Size: 35 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 1996
[-] The following 3 users Like bridgeengineer's post:3 users Like bridgeengineer's post
  • sodapas, PinkPant, Trishu999
  Journal of Composites for Construction - Papers lisine 1 4,865 01-14-2013, 10:25 AM
  CONCRETE & CEMENT SLABS aslam 0 4,538 08-19-2012, 02:21 AM
Last Post: aslam
  Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns kowheng 0 4,526 05-27-2012, 04:46 AM
  Journal of REINFORCED PLASTICS and COMPOSITES mybest 0 3,534 11-27-2011, 08:30 AM
Last Post: mybest
  Portland Cement Pervious Concrete Pavement datagap 0 4,070 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 5,283 03-29-2011, 11:54 AM
Last Post: 3fan
  Bonded Repair and Retrofit of Concrete Structures Using FRP Composites ir_71 0 4,003 02-22-2011, 07:12 PM
