EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied sealants
Author: CEN/TC 227 | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2004 | pages: 20
![[Image: 04501016109532141602.jpg]](https://pic.civilea.com/images/04501016109532141602.jpg)
This document specifies requirements for hot-applied normal and fuel resistant joint sealants to be used in roads, airfields and other trafficked areas. The specification also applies to hot-applied normal joint sealants in bituminous surfacing and between bituminous surfacing and concrete pavements.
EN 14188-2:2004 Joint fillers and sealants - Part 1: Specifications for hot applied sealants
Author: CEN/TC 227 | Size: 0.92 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2004 | pages: 20
![[Image: 77904805616267250344.jpg]](https://pic.civilea.com/images/77904805616267250344.jpg)
This document specifies the requirements for cold applied normal and fuel resistant joint sealants for concrete pavements to be used in roads, parking decks, bridge decks, airfields and other trafficked areas.
This document does not cover the use in gasoline stations, jet fuel stations on airfields and the chemical industry.
![[Image: 63535554433706125161.jpg]](https://pic.civilea.com/images/63535554433706125161.jpg)
