Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 14713 Parts 1, 2 and 3 Zinc coatings — Guidelines and recommendations for the pro
Threads: 1,298
Likes: 25,490 in 1,924 posts
10-10-2014, 01:54 PM
ISO 14713 Parts 1, 2 and 3 Zinc coatings — Guidelines and recommendations for the protection against corrosion of iron and steel in structures
Author: Technical Committee ISO/TC 107, Metallic and other inorganic coatings, Subcommittee SC 4, Hot dip coatings (galvanized, etc.) | Size: 4 MB | Format: PDF | Quality: Original preprint | Publisher: ISO | Year: 2009
[Image: 21755623838199859075.jpg]
ISO 14713-1:2009
This part of ISO 14713 provides guidelines and recommendations regarding the general principles of design which are appropriate for articles to be zinc coated for corrosion protection and the level of corrosion resistance provided by zinc coatings applied to iron or steel articles, exposed to a variety of environments.
Initial protection is covered in relation to
- available standard processes,
- design considerations, and
- environments for use.
This part of ISO 14713 applies to zinc coatings applied by the following processes:
a) hot dip galvanized coatings (applied after fabrication);
b) hot dip galvanized coatings (applied onto continuous sheet);
c) sherardized coatings;
d) thermal sprayed coatings;
e) mechanically plated coatings;
f) electrodeposited coatings.
These guidelines and recommendations do not deal with the maintenance of corrosion protection in service for steel with zinc coatings. Guidance on this subject can be found in ISO 12944-5 and ISO 12944-8.
ISO 14713-2:2009
This part of ISO 14713 provides guidelines and recommendations regarding the general principles of design which are appropriate for articles to be hot dip galvanized for corrosion protection. The protection afforded by the hot dip galvanized coating to the article will depend upon the method of application of the coating, the design of the article and the specific environment to which the article is exposed. The hot dip galvanized article can be further protected by application of additional coatings (outside the scope of this part of ISO 14713), such as organic coatings (paints or powder coatings). When applied to hot dip galvanized articles, this combination of coatings is often known as a “duplex system”.
The guidelines and recommendations in this part of ISO 14713 do not deal with the maintenance of corrosion protection in service for steel with hot dip galvanized coatings. Guidance on this subject can be found in ISO 12944-5.
Specific product-related requirements (e.g. for hot dip galvanized coatings on tubes or fasteners, etc.) will take precedence over these general recommendations.
ISO 14713-3:2009
This part of ISO 14713 provides guidelines and recommendations regarding the general principles of design that are appropriate for articles to be sherardized for corrosion protection.
The protection afforded by the sherardized coating to the article will depend upon the method of application of the coating, the design of the article and the specific environment to which the article is exposed. The sherardized article can be further protected by application of additional coatings (outside the scope of this part of ISO 14713), such as organic coatings (wet paints or powder coatings). When applied to sherardized articles, this combination of coatings is often known as a “duplex system”. General guidance on this subject can be found in ISO 12944-5 and EN 13438. The maintenance of corrosion protection in service for steel with sherardized coatings is outside the scope of this part of ISO 14713.
Specific product-related requirements (e.g. for sherardized coatings on fasteners or tubes, etc.) will take precedence over these general recommendations.
  • Dell_Brett, vvvv, zrilek, PanosP, jcbv, oanm2000, malc, ibg0203, PinkPant, knrsa, peixoto, Mohammad6299
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
06-23-2015, 09:41 AM
BS EN ISO 14713-1-2009
BS EN ISO 14713-2-2009
BS EN ISO 14713-1-2009 (2010)
[-] The following 14 users Like lisine's post:14 users Like lisine's post
  • 3fan, amindoxiti, PinkPant, oanm2000, hodzicemir, Dell_Brett, zrilek, jcbv, K.Lee, malc, serhioSPA, Jackass, scorpion07, kiskertlugas
Users browsing this thread:
