Civil Engineering Association eBooks Journals, Papers and Presentations Pushover analysis of multi-st orey cantilever wall systems
08-10-2014, 02:48 PM
Author: S. Simonini, R. Constantin;A. Rutenberg;K. Beyer | Size: 2012 KB | Format: PDF | Quality: Unspecified | Year: 2012 | pages: 10
[Image: 79342439498166314188.jpg]
Mid- to high-rise buildings are often braced by slender reinforced concrete (RC) walls, which are coupled by RC floor diaphragms. In design it is typically assumed that the walls act independently and the design base shear demand is computed neglecting any compatibility forces between the walls. Pushover analysis of systems
comprising walls of different lengths have, however, shown that large compatibility forces can develop between walls of different length, which should be considered in design, but also that the magnitude of the computed forces is very sensitive to the modelling assumptions. The paper explores by means of a case study of an eight storey structure with two walls of different lengths the shear forces developing at the base of the wall. It compares and discusses the analysis results from different models including simple hand calculations, a lumped plasticity beam element model and a complex shell element model. It concludes that numerical and analytical approaches which are based on the lumped plasticity model tend to overestimate the shear force demand on the shorter wall.
  β€’ amindoxiti, vardan, chenamoy, learner20, blaze, zrilek, malc, PinkPant, Trishu999
  Long-term fatigue analysis of multi-planar tubular joints for jacket-type offshore wi TAFATNEB 1 6,132 06-19-2016, 12:48 AM
Last Post: englandboy
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 5,109 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,664 08-10-2014, 02:52 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,919 08-10-2014, 02:42 PM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 4,279 04-26-2014, 06:15 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,262 04-11-2014, 09:13 AM
  Pushover Analysis of 4 Storey’s Reinforced Concrete Building TAFATNEB 0 4,872 04-09-2014, 06:14 PM
