Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 214: Guide to Evaluation of Strength Test Results of Concrete
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
07-29-2014, 07:52 AM (This post was last modified: 05-06-2023, 07:45 AM by Administrator.)
ACI 214R-11: Guide to Evaluation of Strength Test Results of Concrete
Author: ACI Committee 214 | Size: 260 KB | Format: PDF | Quality: Original preprint | Publisher: American Concrete Institute (ACI) | Year: 2011 | Pages: 16 | ISBN: 9780870314230, 0870314238
[Image: 84955888381706576394.jpg]
This guide provides an introduction to the evaluation of concrete strength test results. Procedures described are applicable to the compressive strength test results required by ACI 301, ACI 318, and similar specifications and codes. Statistical concepts described are applicable for the analysis of other common concrete test results, including flexural strength, slump, air content, density, modulus of elasticity, and other tests used for evaluating concrete and ingredient materials. This guide assumes that the concrete test results conform to a normal distribution.
Most construction projects in the United States and Canada require routine sampling of concrete and fabrication of standard molded cylinders. These cylinders are usually cast from a concrete sample taken from the discharge of a truck or a batch of concrete. They are molded and cured following the standard procedures of ASTM C31/C31M and tested as required by ASTM C39/C39M. If the concrete is so prepared, cured, and tested, the results are the compressive strength of the concrete cured under controlled conditions, not the in-place strength of the concrete within the structure. It is expected that, given the uniformity of the curing conditions, these cylinders would have essentially the same strength, thereby indicating concrete with consistent properties. It is these cylinders that are used for acceptance purposes.
Inevitably, strength test results vary. Variations in the measured strength of concrete originate from two sources:
• Batch-to-batch variations can result from changes to the ingredients or proportions of ingredients, water-cementitious material ratio (w/cm), mixing, transporting, placing, sampling of the batch, consolidating, and curing; and
• Within-batch variations, also called within-test variations, are primarily due to differences in sampling of the batch sample, specimen preparation, curing, and testing procedures.
There are differences in individual mixer batches between the front and rear of the mixer, as recognized by ASTM C94/C94M. For this reason, ACI Field Level I Technicians are trained to make composite samples from the central portions of loads.
Conclusions regarding concrete compressive strength can be derived from a series of tests. The characteristics of concrete strength can be accurately estimated when an adequate number of tests are conducted in accordance with standard practices and test methods.
Statistical procedures provide valuable tools when evaluating strength test results. Information derived from them is also valuable in refining design criteria and specifications. This guide discusses variations in concrete strength and presents statistical procedures useful for interpreting them with respect to specified testing and acceptance criteria.
For the statistical procedures described in this guide to be valid, data should be derived from samples obtained through a random sampling plan. Random sampling is when each volume of concrete has an equal chance of being selected. To ensure this condition, selection should be made by using an objective mechanism, such as a table of random numbers. When sample batches are selected on the basis of the sampler's judgment, biases are likely to be introduced that will invalidate the analysis. Natrella (1963), Box et al. (2005), and ASTM D3665 discuss the need for random sampling, and provide a useful short table of random numbers.
[-] The following 24 users Like Mohammad6299's post:24 users Like Mohammad6299's post
  • Dell_Brett, amindoxiti, zrilek, ssobhan, PinkPant, cace-01, oanm2000, Jackass, ir_71, malc, araza023, essenza, knrsa, bigone, Rapaig, harsono, simanta, milova, jayborre, GMianG, pram, cabpcabp, kristoffer_89, spat
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
05-06-2023, 07:44 AM
ACI PRC-214-11 Guide to Evaluation of Strength Test Results of Concrete (Reapproved 2019)
Author(s)/Editor(s): ACI Committee 214 | Size: 315 KB| Format: PDF| Quality: Original preprint| Year: 2011 (2019) | ISBN: 9780870314230
[Image: 10311701957431914514.png]
Price: $ 59.50 USD
ALSO AVAILABLE IN:
ACI Collection of Concrete Codes, Specifications, and Practices - Digital Subscription
ACI Concrete Repair Subscription
Choose Product Language
English
Choose Product Units
SI and IN-LB units
Choose Product Format
PDF (free access to members)
Multi-User Options
Description(Abstract)
Document Details
Table of Contents
Errata Info
Return/Exchange Policy
Notes/Preview
Preview
Description
Statistical procedures provide valuable tools for evaluating the results of concrete strength tests. Information derived from such procedures is valuable in defining design criteria, specifications, and other parameters needed for structural evaluation and repair. This guide discusses variations that occur in concrete strength and presents statistical procedures useful in interpreting these variations with respect to specified testing and criteria.
Keywords: coefficient of variation; concrete strength; normal distribution;required overdesign; quality control; standard deviation; statistical methods.
  • Dell_Brett, babakfeyzi, Umer.Aleem, PinkPant
  [CivilEA Exclusive] ACI SP-364: Serviceability and Performance Evaluation of Concrete Bridges and Structu poolmand 0 2,572 04-19-2025, 12:42 PM
  ACI E702.8: Designing Concrete Structures: Evaluation of Concrete Cores Test Results poolmand 0 1,429 08-28-2024, 06:12 AM
  [CivilEA Exclusive] ACI 506.4: Guide for the Evaluation of Shotcrete poolmand 0 1,598 11-06-2023, 10:22 AM
  ACI 369.1: Seismic Evaluation and Retrofit of Existing Concrete Building agelos100 4 4,683 11-05-2023, 07:05 AM
  [CivilEA Exclusive] ACI 364.7: Evaluation and Minimization of Bruising in Concrete Repair poolmand 0 1,710 11-05-2023, 06:59 AM
  ACI 363: Report on High-Strength Concrete Mohammad6299 1 2,528 05-07-2023, 05:28 AM
  ACI 363.2: Guide to Quality Control and Assurance of High-Strength Concrete Mohammad6299 1 2,124 05-06-2023, 12:09 PM
