AutoCAD® software with AutoCAD® Structural Detailing and Revit® Structure software for a complete modeling, documentation, detailing, and fabricationshop drawing toolset.
A building information modeling (BIM) application, Revit Structure integrates multimaterial physical and analytical models, providing concurrent structural modeling for more accurate documentation, analysis, and design. AutoCAD Structural
Detailing is a powerful solution for fast and efficient detailing and automatic creation of fabrication shop drawings for steel and reinforced concrete structures.
Accelerate your structural engineering workflow from early design through fabrication with the efficiency of BIM and easy-to-use AutoCAD applications.
AutoCAD Revit Structure Suite includes AutoCAD, Revit Structure and
AutoCAD Structural Detailing software products.
DVD1 : Revit Structure
DVD2 : Autocad (for Revit Structure Suite)
DVD3 : AutoCAD Structural Detailing
Installation:
unpack, burn or mount & install.
check Crack/install.txt on DVD1
LINK:
>> First learn from cracked software than be licensed1 <<
